Hi Gary,
Aim for a joint gap of about 0.1mm radial.
Aim for a joint length of 5-6x wall thickness of the tube.
Ensure components are free of grease. Use appropriate flux.
Ideally position soft solder (ring?) Inside the nipple. Like a Yorkshire fitting
Heat the nipple to draw the solder through the joint.
90 psi? a walk in the park.
Expect a joint strength 100 x that
Keith
