Paint
Paint
Home › Forums › General Questions › Paint
  • #113066
    mark mc
      @markmc72333
      Hi all, this might sound like a silly question but what is a good paint for cast iron. I'm making a engineers level from the castings over at ces. I have the machining done but would like to paint the rough parts say green. what's a good paint to stick to cast iron ? Do i need to prime it first.
      #22490
      mark mc
        @markmc72333
        #113068
        Gray62
          @gray62
          I have painted a couple of machines with Wilkinsons own brand metal paint, priming with red oxide first. They do a good 'classic' type grey as well as a decent green and blue. This paint seems to be suitably resistant to most oils and lubes found in the average home workshop (well mine at least).
          I did look at using hammerite at one point but after enquiries with the manufacturer I was advised that it was not resistant to many common oil based products.
          Hope this helps
          Graeme
          #113070
          KWIL
            @kwil
            Give the cast iron a good scrub with a wire brush to remove any loose carbon particle in the cast iron surface, Red oxide it straight away.
            #113100
            mark mc
              @markmc72333
              No worries thanks, will get some orderded.
              #113102
              Andyf
                @andyf
                Hearsay only:
                On other forums, folk have reported good results with floor paint on machinery, for its hard-wearing quality and resistance to oil etc.
                Andy
                #113105
                Anonymous
                  I used Hammerrite on my rotary table, universal dividing head and pillar drill with no problems so far, apart from the odd chip here and there. The floor paint I used on the floor has long since worn away.
                  #113110
                  Andyf
                    @andyf
                    I'm no paint expert, but the Hammerite might have worn a bit quicker than your floor paint had you used it on the floor and then walked/trod swarf into/dragged things across it.
                    Andy
                    #113118
                    Windy
                      @windy30762
                      My friend painted his full size Fordson Dexter with Tractol paint it is also used on construction equipment.
                      On its first show it won top award.
                      On the steel and cast iron it looks great if you use the correct primers etc they have a good range of colours RAL, BS 381C & BS 4800
                      Paul
                      #113119
                      Derek Drover
                        @derekdrover32802
                        Wilkinson do a very good spray enamel, in a variety of colours. The matt black is very good for model engineering (and used on the hugger of my motorbike).
                        del.
                        #113291
                        Sub Mandrel
                          @submandrel
                          I thought I had already posted this, but I find Humbrol enamel works well on small items, using ordinary brown or grey spray primer.
                          Several of my machine tools/vices came with a 'hammerite' finish.
