Hi guys, my 'other' hobby is flying RC Helicopters, of which I have a fair few. I have an issue with a manufactured part that I'd like your opinions on please.
On a brand new machine which uses a .91/120 nitro engine (around 18-20cc) It has a poorly machined clutch hub. The diameter of the engine crank is 9.50mm, but the hub is 9.59mm (internal mic used) The hub has a split collar and 2 pinch bolts. So once installed onto the crank, you would normally tighten the crank nut, and then pinch it for extra force on the crank. But it's so loose, there is no way that pinching with both tighten it and hold it centred!! There's the weight of steel clutch shoes installed to the other side of this hub!!
So, seeing as just buying a new one will have the same miss tolerance, I'm thinking about sleeving this one. I have a 9.5mm reamer, so what I would like your advise on is what wall thickness for the sleeve and what material please?
I'm thinking that if I mount the hub in the 4 jaw and clocking it dead centre, I could ream it to say 10.5 – 11.00mm, and then machine a sleeve in brass to match with a reamed 9.50mm bore. This can be pressed into the hub, and slotted along the existing slots, so it all clamps as one unit. What do you think please?
Cheers, Rob
