Other Motor Use
Other Motor Use
Home Forums Workshop Tools and Tooling Other Motor Use
  • #193142
    Colin LLoyd
      @colinlloyd53450
      I refuse to throw away electric motors that still work – but haven't yet put any of them to good use in the workshop – oh except one where I converted a 12v battery drill/driver motor to a dedicated flexible shaft setup for drilling, rotary filing and sanding in difficult places.
      I have several hover mower motors with belt drive on rigid plates to bearings where the blade is normally held. Has anybody got any good ideas as to how I can put these to use in the workshop. If you lot can't think of practical uses – then no-one can, and I might as well scrap them.
      #17735
      Colin LLoyd
        @colinlloyd53450
        #193145
        John Rudd
          @johnrudd16576
          Errmmmm depending on the rating of the motor, you could use one to make a variable speed bench grinder…..
          A decent speed controller and some wheels, a bit of metal would make a nice vari speed machine, probably more versatile than the fixed speed models…..
          Assuming of course we are talking brushed motors….
          #193159
          Ajohnw
            @ajohnw51620
            I don't know how big these are but lathe tool post grinders don't need a lot of power, neither does tool post mounted milling arrangements either really for key ways and other light jobs.
            john carruthers
              @johncarruthers46255
              mini wind turbines if they're suitable ?
              #193172
              john fletcher 1
                @johnfletcher1
                Before using the motor to power a grinder, ensure that the motor speed and recommended speed of the grinder wheel are compatible. I don't think they are suitable for a wind turbine either, you need to alter the field system for that.Ted
                #193175
                Rainbows
                  @rainbows
                  If they still work you can get a bit more money selling than scrapping.
                  You could make a belt grinder: useful for shaping metal.
                  If you do wood work you could make a disc sander or a wood turning lathe.
