Old copper tanks
Old copper tanks
Home › Forums › The Tea Room › Old copper tanks
Viewing 25 posts - 1 through 25 (of 25 total)
  • #819376
    larry phelan 1
      @larryphelan1
      Old copper tanks
      Good afternoon all,
      I have two old hot water tanks, obtained when both were replaced recently .Just looking at them, before I take them to the scrappy, there is quite a lot of copper sheet there, and this set me wondering has anyone else ever found a new use for such tanks ?  I do not make models but it seemed to me that there could be enough there to make boilers or some other parts for models, or indeed some other use.
      Any ideas ??
      PS   I hate to throw out anything and then find a use for it later !
      #819378
      Martin Kyte
        @martinkyte99762
        Fred Dibnah used to make his weather vanes from old copper tanks.
        #819380
          On larry phelan 1 Said:
          Old copper tanks
          Good afternoon all,
          I have two old hot water tanks […]
          Any ideas ??
          Check the price of scrap copper
          … especially if they have heating pipes inside !
          larry phelan 1
            @larryphelan1
            Yes Michael, they do !
            #819399
            Bazyle
              @bazyle
              The old ones are much more useful than the new ones covered in foam. They are too thin for a lot of uses but are good for a) model boat sheeting over wood if recreating the plates of so many historic ships.
              b) making small feed water tanks in model boats that are not pressurised
              c) slug repellers for gardeners
              d) electrodes for copper plating
              #819401
              larry phelan 1
                @larryphelan1
                Much as I thought, Bazyle !
                #819403
                noel shelley
                  @noelshelley55608
                  There use is dependent on what they were, mains pressure or gravity fed. Gravity tanks are thin but the sheet copper is useful for many things. Mains pressure will be much thicker eg 1.2mm and are very handy BUT they do not go as copper at the scrap yard unless you cut out all fittings and seams, as they are they are classed as brazery copper a lower class/price and if foam covered even lower.  Before going to a scrap yard phone round for prices, also remember they change daily. Good luck. Noel.
                  #819412
                  Bo’sun
                    @bosun58570
                    Cut off the concaved base, upturn it, and use it as a bird bath.
                    #819414
                    Speedy Builder5
                      @speedybuilder5
                      Cut the thin the copper into the form of leaves, use a brick bolster to tap the veins of the leaves into the shapes and then make very presentable garden ornaments for your loved one.
                      I made a water fountain feature where the water rose up through some copper tube, onto the top leaf and slowly splashed its way down the other leaves back into the pond.
                      bob
                      #819416
                      Andy Stopford
                        @andystopford50521
                        I made a brewing copper out of one.
                        #819429
                        Andrew Tinsley
                          @andrewtinsley63637
                          My father made a couple of exquisite candle sticks and a large log box out of my scrap tank.
                          Andrew.
                          #819433
                          Grindstone Cowboy
                            @grindstonecowboy
                            If you remove the foam, you get a bit more as scrap – last one I did a few years ago raised about £70.
                            Rob
                            #819437
                            paul rushmer
                              @paulrushmer83015
                              I also have a bird bath made from the upturned base, one of my grandfathers locos has the boiler clad with the sheet from the centre section. One day I hope to make some 3 1/2 gauge box vans with corrgated ends made from these.
                              Paul
                              #819442
                              noel shelley
                                @noelshelley55608
                                To Andy I say go the whole hog and make a still – you always need distilled water ! To the rest of you God bless and good night ! Noel.
                                #819483
                                larry phelan 1
                                  @larryphelan1
                                  I agree, I think Andy has the best idea !
                                  My thanks to all.
                                  #819487
                                  Richard Simpson
                                    @richardsimpson88330
                                    Around 40 years ago now I rewired a house.  Typical mid-war semi.  I kept all the old wire that was removed and put it into a large suitcase.  When I’d finished I took the lot down to my local scrap merchant and was very pleasantly surprised at what I got for it all.  I would have got a bit more had I bothered to strip the insulation but decided life was too short.
                                    The trouble with an old tank is where to store it and process it while you decide on the best course of action.  Take it down the scrap yard and put a bit of money in your pocket.  If you can’t resist the urge to do something with them, cut them in half and put them in the garden with some plants in them.
                                    #819497
                                      Here you Go Larry, nice little winter project for you!!
                                      #819509
                                      Alan Donovan
                                        @alandonovan54394
                                        Hi.
                                        I ‘lost out’ on an old copper tank recently.  My son was having his plumbing and heating upgraded in his old house.  He had agreed that I could have the copper tank.
                                        That never arrived because the plumber said that he quoted his price on him reclaiming the metal in the tank ………….  Funny thing is – my son was only made aware of this  on completion of the work and my son never saw a ‘credit’ for the value of the tank on the invoice.
                                        A.
                                        #819528
                                        not done it yet
                                          @notdoneityet
                                          Weigh them in.  The scrappy would pay you a considerable amount for them!
                                          #819547
                                          parovoz
                                            @parovoz
                                            Love the Steampunk engineering on the compressed air bike…. But it doesn’t look as though it’s really a proper ‘runner’. But still a work of art…..
                                            #819579
                                            old mart
                                              @oldmart
                                              If you want to salvage some of the copper before taking the remainder to the scrapyard, knock out any deposits if there is any limescale inside. The scrappie buys by weight and only wants the copper.
                                              #819585
                                              Bazyle
                                                @bazyle
                                                Our Men’s Shed collects things like copper flex and twin&earth ‘ends’ after second fix for a place where people with learning difficulties strip out the copper. It is fun occupational therapy and increases the scrap value for the organisation. See if you can find a similar place near you that you can support with your ‘scrap’.
                                                #819593
                                                Martin Kyte
                                                  @martinkyte99762
                                                  There are ‘hopefully’ many less of them about but the first house I bought circa 1980 had a rare old mix of cable. Some lead covered which actually wasn’t too bad electrically but stacks of rubber insulated which when you took in both hands and bent just shed all the insulation leaving bare wire. The house was a fire waiting to happen.
                                                  #819628
                                                  larry phelan 1
                                                    @larryphelan1
                                                    Some great ideas there alright !
                                                    Just checked those tanks, they weigh in at 8Kg each. Price of scrap copper seems to be from 3Euro to 7 Euro per Kg.
                                                    Might hold on to them for a while.
                                                    PS  I like that bike idea !
                                                    #819636
                                                    noel shelley
                                                      @noelshelley55608
                                                      I believe copper prices are now high and when checking remember they are brazery copper not No 1. Noel.
