Newby machine help please
Home › Forums › Beginners questions › Newby machine help please
Viewing 25 posts - 1 through 25 (of 37 total)
  • #283568
    Marc Jonah
      @marcjonah71323
      Hi all, I'm a bit new to this lathe lark but being a farmer I need one every now and again for repairs etc.. I bought a cheap Mitchell lathe from eBay and want to do some threading on it but I can't make out how to set the gears, I'll attach some pic and probably some of you may be able to point me in the obvious (but not to me) direction please. I'm not sure if I'm missing some more gears or whatever but I've trawled the Internet and looked for a manual etc for the machine but to no avail… Any help will be great fully received.
      Marc
      #8559
      Marc Jonah
        @marcjonah71323
        #283569
        Marc Jonah
          @marcjonah71323
          pics in album
          Edited By Marc Jonah on 10/02/2017 22:04:07
          #283570
          David George 1
            @davidgeorge1
            Post the pictures in an album and then anyone can see them if you like.
            David
            #283571
            Marc Jonah
              @marcjonah71323
              Many thanks David, I've just done that. I think.
              #283572
              Nick_G
                @nick_g
                Hello Marc,
                Where in the country are you.? Somebody may be able to show you.
                Edit :- Just looked at your previous posts. I see you are in south Wales.
                Nick
                Edited By Nick_G on 10/02/2017 22:08:45
                #283578
                David George 1
                  @davidgeorge1
                  Hi Marc You can look up Woodhouse Mitchell lathes on Lathes.co.uk web site ( Tony's lathes)
                  David
                  #283579
                  Marc Jonah
                    @marcjonah71323
                    Cheers David, I have emailed to you about it and he sent me what he had but wasn't the same as my lathe, I sent him some pictures back but didn't hear anything further.
                    #283581
                    Hopper
                      @hopper
                      It looks like to cut imperial threads (Threads per Inch) you can just use the levers set as per the chart next to them.. Then to cut metric threads, you have to position the levers and the extra change gears as per the extra metric square chart attached to the machine. The abbreviations on that chart mean "Driver" being the first gear in a meshing pair, the one on the lathe spindle that drives the next gear in the train and so on, and "Driven" meaning the gear that comes second in the pair and is driven by the other gear, eg the gear on teh leadscrew or the gearbox input shaft.
                      Confusing in writing I know. Would be nice if you could get someone over to show you the ropes in person.
                      #283584
                      Simon Williams 3
                        @simonwilliams3
                        Could you post a picture of the left hand of the headstock – end on so we can see the gear train please. You've took the cover off, and there is a picture of some of the gears but the rest are lost in the shadows.
                        Thx Simon
                        #283592
                        Marc Jonah
                          @marcjonah71323
                          Many thanks, I've just added another picture side on in which you will see the only 4 gears I have which are 63-60-42-40.
                          Cheers
                          Marc
                          #283593
                          Marc Jonah
                            @marcjonah71323
                            Posted by Marc Jonah on 10/02/2017 22:52:17:
                            Sorry David this was meant to say "I have emailed Tony about it"
                            #283600
                            Scrumpy
                              @scrumpy
                              Hi After looking at your pictures I think it's the same as mine it's a 8 1/2 X 10 or 12 lathe as per the gearing mine is set up for imperial screw cutting the gears on the end are 40 – 60 – 40 looking at the front panel the top 3 leavers are for speed the 1 next down is for travice
                              The 2 leavers on the angle are for feed and cutting imperial threads there are to figures one on top of each other top for threads bottom for feeds
                              3 leavers below are 2 on left feed and screw cutting 1 on the right to engage lead screw panel on the end is for metric you have got in my mind a very good lathe
                              #283602
                              Bazyle
                                @bazyle
                                The label seems to suggest different gears on the end for imperial so with a 63 on the banjo it is probably set for metric. Can't see on the label what it says. Try cleaning the labels and posting new pictures.
                                The first thing would be to set for say 1mm and put a piece of plastic water pipe in the chuck. Use this to scratch a thread, no need even to cut, and see if it measures up to the setting to prove the end gears are right.
                                Edited By Bazyle on 11/02/2017 09:38:23
                                #283605
                                Bazyle
                                  @bazyle
                                  When setting the two top levers 13N57 etc make sure the other lever is in N or the gearbox will jam.
                                  The lower levers AB, CD are each power of two ie doubling the mitch which can work together to give a power of 4.
                                  When looking at the metric table as said above the gears go spindle/banjo/banjo/gearbox or as written Driver/driven/driver/driven with the two middle ones on the same axle so you are getting two stages of reduction.
                                  Did you get any loose gears? like another 40 and a 48?
                                  #283608
                                    You can put album pictures into a post using the black camera icon in the 'post a reply' box.
                                    Marc Jonah
                                      @marcjonah71323
                                      This is what I presumed but, I didn't get any other gears with it so it wasn't making any sense to me. I'll set the gears I have to match one of the metric threads and give it a go. Thanks for your help all, I really appreciate it. Do you have any pictures of yours scrumpy?
                                      #283619
                                      Scrumpy
                                        @scrumpy
                                        Hi I have just been to the workshop and checked to make sure you are given the correct information
                                        The 2 middle levers feed and screw cutting are numbered LH 5-1-N -3-7 RH 6-2-N-4- blank the bottom leavers are marked LH- B – A RH -D-C with the other lead screw
                                        To cut a thread of 30 tpi the gearbox should be set to 3-BD on levers 40 driving intermediate 60 driven
                                        40 tpi gearbox 3-BD with 30 driving intermediate 60 driven
                                        10 MM Pitch 3-AC on gearbox with 45 driven to a 60 intermediate 63 second intermediate to 48 driven
                                        A full set of gears are 30 40xtwo 42 44 45 46 48 57 60 63 80
                                        hope this helps
                                        #283628
                                        Russell Eberhardt
                                          @russelleberhardt48058
                                          With that combination of gears it looks as if it's set up for 1¾, 3½, 7, and 14 mm pitch. Not very usefulsad
                                          Russell.
                                          #283629
                                          Bazyle
                                            @bazyle
                                            Scrumpy, next time you are out there best measure the DP of the gears and hole/keyway details. Looks like Marc will have to get another 40 from Devall or somewhere for the imperial side.
                                            #283634
                                            Marc Jonah
                                              @marcjonah71323
                                              Thanks guys, I suppose I'm now in search for a full set of gears, now possibly the silly questions bit…. are bit like this still available or are you suggesting having them made?
                                              Thanks
                                              Marc
                                              #283646
                                              Scrumpy
                                                @scrumpy
                                                Hi I have looked and the manual again and I cannot see head or tail what Russell is talking about, Marc on looking at your photos what gears do you have ,
                                                One small tip if you put the speed leavers in neutral with the motor running and pull the leaver to run the internal pump until oil runs through the sight glass top right this allows the headstock bearings to be lubricated you have a very good lathe
                                                #283650
                                                Bazyle
                                                  @bazyle
                                                  The gear highest up in the sequence will be linked directly to the spindle and probably rotate at the same 1:1 ratio with the spindle (check this). We can call it the spindle gear as if it were directly on there. The bottom gear should be the input to the gearbox
                                                  The gears are at a random position at the moment if I am getting the picture rotated right in my head. The 63 appears to be on the input to the gearbox ie a driven gear. It is never required in this position.
                                                  Imperial. The plate by the top left lever says eg "60,40,INT" and "40, 40, INT" the INT stands for "intermediate" and is just to bridge the gap between the other two gears so it will not change the ratio and can be any gear that fits.
                                                  The middle top plate shows you the threads you will get eg for third column 8,9,10,11,12,13,14 for each lever number setting BUT only if you have 40: INT 40 on the gears.
                                                  For the moment you are gong to have to put 40 on the 'spindle' and 60 on the gearbox with whatever fits, probably your 42 in the middle to bridge the gap.
                                                  #283651
                                                  Bazyle
                                                    @bazyle
                                                    This means you get threads which are finer than the plate by 60/40 eg 8 becomes 8×60/40 = 12
                                                    The table then becomes (should be 5 columns but can't paste properly from Excel)
                                                          ac   bc   ad   bd
                                                    1    3     6    12     24
                                                    2     3.375 6.75 13.5 27
                                                    3     3.75  7.5  15    30
                                                    4     4.125 8.25 16.5 33
                                                    5     4.5    9     18        36
                                                    6     4.875 9.75 19.5 39
                                                    7     5.25 10.5  21     42
                                                    column on the left is lever position 1,2,3,4, etc
                                                    Edited By Bazyle on 11/02/2017 15:13:49
                                                    Edited By Bazyle on 11/02/2017 15:29:24
                                                    #283653
                                                    Bazyle
                                                      @bazyle
                                                      For the missing gears you can still get industrial gears from eg Devall but the hole in the middle and the keyway probably won't be as required. You need to know the 'Diametric Pitch' or DP. Take the 60 gear, measure the diameter over the teeth in inches, calculate (60+2)/(diameter). It will be a round figure like 12,14,16. If it is not a round figure it may be metric which we can tackle later.
                                                      Devall look under "spur gears inch"
                                                      You will be able to sort out the hole size and keyway on your lathe after a bit of practice. COme back for advice when needed.
