Galvanized nut binds halfway down — where would you start?
Home › Forums › General Questions › Galvanized nut binds halfway down — where would you start?
  • #871721
    elowen01
      @elowen01
      Hi all,
      Quick one about hot-dip galvanized bolts and nuts.
      The nut starts fine by hand, then gets tight halfway down the thread. It doesn’t feel cross-threaded, just like it’s binding.
      What’s the first thing you’d check? Try a different nut, run a thread gauge over it, check pitch diameter, look at coating buildup?
      And should a galvanized nut run all the way by hand, or is a bit of resistance normal?
      Just trying to get a sensible order to check things before I start guessing.
      Cheers.
      #871753
      Bazyle
        @bazyle
        Is that half way down the nut depth or halfway down a yard of all-thread? if the former it is often due to it being a mix of UNC nut on Whitworth bolt, or metric and similar imperial bolt. For the latter it will be a zinc snot on the threaded rod.
        #871756
        noel shelley
          @noelshelley55608
          As Bazyle has said check that you do infact have the right nut. Whilst zinc coated eg hot dip will stop corrosion it will not improve it’s mechanical attributes. You do not indicate what your doing with it, but heavy loading will cause the zinc to cold weld, fine for fixing timber on a beach but no good if it’s being used as an extractor. I’m picking up some 16mm threaded rod today, I don’t want galv and will be using plain 8.8 grade (bolt) not mild steel.  Noel.
          #871757
          Neville Chase
            @nevillechase52412
            Try a non gal nut on the gal bolt and the gal nut on  a non gal bolt and see what happens.
            #871789
            JA
              @ja
              Try lubricating both threads completely with a heavy oil oil or grease. On final assembly use a spanner or socket by hand, not a power wench.
              This may work, it is advice given by the British Stainless Steel Association for preventing galling on stainless nuts and bolts.
              JA
              #871796
              DC31k
                @dc31k
                Take a spare, unplated nut, put a hacksaw cut into it and also cut the threads opposite the cut (to make proto-cutting teeth). Wedge it open just a tad and run it down the male thread. Try the proper nut and see if the problem is solved. If not, reduce the tad to half a tad, repeat the chase and try again.
