My layman’s view is that these devices don’t alter the supply frequency and therfore will not soft start the type of induction motor normally fitted to a machine tool. I presume that they are suited to ac brush motors etc. Happy to be corrected.
That’s interesting, I’ve never seen these before either. If you go ahead, I’d like to know the results! My milling machine has a 2hp motor that starts with quite a bang. I intend to fit a 3 phase motor and vfd in the future but thats a £500+ expense. It would be nice to smoothen the start.
Unless you are determined to pay top dollar for a new plug’n’play system, there are far better (cheaper) options, IMO.
I’ve used cheaper chinese VFDs for several years and have a good surplus 1.5kW three phase motor available at far less than the cost of a new motor – even worn motors are generally recoverable at minor cost.
Obviously a more expensive VFD would be required for a 415V output, but one could purchase a 3 HP three phase motor @ 415V star and run it on a 220V output VFD without changing the motor to delta configuration – but at a bit less than 2HP output. There are options.🙂
