Need some decent windmills and slot drills
Home › Forums › Workshop Tools and Tooling › Need some decent windmills and slot drills
Viewing 21 posts - 1 through 21 (of 21 total)
  • #154697
    Jamie Jones
      @jamiejones42723
      HI
      When I purchased my mill I purchased a set of 20x endmills and slotdrills with smooth shanks to use in a 3mt collet holder system.
      Can anyone recommend some decent cutters at a sensible price and from a good supplier..
      #17407
      Jamie Jones
        @jamiejones42723
        #154702
          Can't help with the windmills but for cheap endmills and slotdrills the one that I used in the video I posted in your other thread came from Richon. They are certainly cheap but do a reasonable job and will be good to learn with without the worry of mucking one up, the HSS 4 and 2 flute ones will do.
          In the smaller sizes the FC-3 disposable cutters work out to be quite economic especially if you wait for suppliers to have them on special. Try Cutwell, cromwell or the weekly flyer from MSC (Hertel ones on page 13)
          J
          #154704
            Alternatively, take a look at the advertisers on this site. All the ones who supply lathes and mills also supply tooling.
            Jamie Jones
              @jamiejones42723
              Posted by Jamie Jones on 07/06/2014 20:15:30:
              HI
              Should read endmills …. The wonders of iPhone editing what you type.. Strange that when I quote the text it reads correct while I type this message..
              #154709
              Jamie Jones
                @jamiejones42723
                Should add the supplier has to be UK based and phone contactable because I don't use my card on the Internet.
                #154710
                Oompa Lumpa
                  @oompalumpa34302
                  My late father almost bought a Windmill. That would have been fun!
                  Anyway, I rarely pay more than £2 for a new cutter as I find them at my local second hand tool shop still boxed up for that, just can't be fussy on sizes so I I buy what is there and the odd special size for a job as and when I need them. Thing is, I now seem to have quite a lot!
                  graham.
                  #154711
                    Try Tracy Tools, if you don't mind odd sizes they have some big bargains, such as rippa cutters down to about £4 (bear in mind that for most cuts the exact diameter doesn't matter).
                      Posted by Jamie Jones on 07/06/2014 21:14:18:
                      Jamie,
                      It does read correctly in the post … it's only the thread Title that's wrong.
                      You can't fix that yourself; it will need to be one of the Moderators.
                      NJH
                        @njh
                        I'd leave it as it is – I like the idea of "Windmills" ( Far more interesting than boring old endmills that keep coming up here! )
                        Norman
                        #154725
                        WALLACE
                          @wallace
                          Round,
                          Like a casting on a faceplate
                          Like the backgear of the mill
                          Never ending or beginning
                          Like the chuck that’s on the drill
                          Or a centre in the tailstock
                          Or a green grit grinding wheel
                          Like a Myford lathe that’s turning
                          Parting endless bars of steel
                          Like a clock whose hands are sweeping
                          Past the ‘thou’ upon its face
                          And the world is like a lead screw
                          Twisting endlessly in space
                          As the collet chuck unwinds
                          Off the ENDMILLS of your mind…..
                          Sorry…I couldn’t resist it !
                          W.
                          Edited By WALLACE on 08/06/2014 00:09:23
                          Edited By WALLACE on 08/06/2014 00:10:32
                          Edited By WALLACE on 08/06/2014 00:21:15
                          #154726
                            Posted by WALLACE on 08/06/2014 00:07:42
                            … Sorry… couldn't resist it ! W.
                            Brilliant !!
                            GaryM
                              @garym
                              Wallace,
                              If you've composed that in the four hours since this thread was started you should be a songwriter. Superb.
                              Gary
                              #154734
                              NJH
                                @njh
                                Wallace
                                EXCELLENT!!
                                A man after my own heart.
                                Norman
                                #154735
                                  Jamie, MSC that I linked to will deal over the phone.
                                  Although some of our suppliers on the site or in the mag do low cost cutters they are not always of a high quality as you found out with the set you got from one of the machinery suppliers. For times when it matters go for the named brands like Hertel or Guhring and if your pockets are deep enough Dormer.
                                  I corrected the text in the post but left the title as it would make a lot of the replies seem out of place
                                  #154736
                                  Gary Wooding
                                    @garywooding25363
                                    Wallace,
                                    will you give permission for it to be published in my club's newsletter?
                                    Gary
                                    #154738
                                    Speedy Builder5
                                      @speedybuilder5
                                      Windmills – this was my Grandfather's mill down in Rochester Kent – sadly demolished now.
                                      I bought about 10 bags of end/slot and form mills from a tool and cutter grinder who supplied the motor industry. When the tools have been ground and are no longer an exact size , they are binned. Quite cheap at £10 a bag. Just the job for us lot.
                                      BobH
                                      #154739
                                      WALLACE
                                        @wallace
                                        Hi Gary – by all means ! It took about 30 minutes in the bath last night to ‘modify’ the original … and I couldn’t get the song out of my head for the rest of the night !
                                        W.
                                        #154743
                                        Gary Wooding
                                          @garywooding25363
                                          Thank you Wallace.
                                          #154749
                                          Bob Brown 1
                                            @bobbrown1
                                            You could use flea bay just try a search for Dormer end mill and if you are concerned about using you card on the internet get a pre paid card so even if the details get stolen the worst that can happen is you lose what you have put in there and the chances of that happening is still remote.
                                            Note; You can use screwed shank in an ER collet, I have quite a few that I use in my ER40 collet chuck.
                                            Edited By Bob Brown 1 on 08/06/2014 09:59:50
                                            #154757
                                            Ian S C
                                              @iansc
                                              One of the major contributors to ME in the 1990s I think (might have been on staff) lived in a converted Windmill.
                                              Ian S C
