Myford Super Seven help
Home › Forums › Help and Assistance! (Offered or Wanted) › Myford Super Seven help
  • #33526
    Glen Nutting
      @glennutting14250
      New oil wick too big
      #451509
      Glen Nutting
        @glennutting14250
        Hi everyone. Just restoring my Myford super seven it dates from 1961.
        Replacing the bronze front headstock bearing. I have found the original bearing has a much smaller hole for the oil wick .so the new oil wick and new oil wick spring are much too big for the hole. Anyone else come across this as it looks like Myford have changed the size at some stage but still use the original part numbers??
        #451518
        Phil P
          @philp
          I somehow doubt it, but its possibly worth asking Myford if they know the answer.
          Its not very good engineering practice to use the same part number for a changed part if it is not "Fit Form & Function" though.
          Sorry I cannot be of more help.
          Phil
          #451522
          not done it yet
            @notdoneityet
            The usual engineering convention, for numbering parts with later modifications, is to use the same basic part number but with either a prefix or suffix to denote the modified/improved design.
            #451531
            Brian H
              @brianh50089
              Can the hole be enlarged to fit?
              #451534
              Hopper
                @hopper
                Reach out to Myford. They are very helpful.
                #451539
                Swarf, Mostly!
                  @swarfmostly
                  I suggest that approaching Myford (Mytholmroyd) just now should be done with sensitivity – according to the news this morning, that community has suffered yet another serious flood problem.
                  Best regards,
                  Swarf, Mostly!
                  #452112
                  Steviegtr
                    @steviegtr
                    Have a look at this.
                    Front bearing differences over the years
                    Hope this helps
                    Steve.
