Myford Super 7 Bed for Power Cross Feed
Home › Forums › Workshop Tools and Tooling › Myford Super 7 Bed for Power Cross Feed
  • #412915
    Mike Donnerstag
      @mikedonnerstag
      Quick question: I have an early 80s Super 7 with gearbox and power cross-feed. I am looking to replace my worn bed and wondered what differentiates the various beds. Specifically, what makes a bed a power cross-feed bed?
      #19358
      Mike Donnerstag
        @mikedonnerstag
        #412918
        John Haine
          @johnhaine32865
          Nothing as far as I know, they're identical.
          #412933
          Phil Boyland
            @philboyland37326
            Only difference is in the saddle, apron and lead screw I believe.
            #412934
            Peter Sansom
              @petersansom44767
              Just ge the bed reground. Others in your region will be able advise as to where to get ths done. If nothing else locate a shop with a surface grinde that will accomodate the bed.
              I believe that there is a difference in the bed castings, certainly between the pre and post power crossfeed Super 7's. don't know if the ML7R bed is the same as the Power Crossfeed Super 7.
              #412939
              Brian Oldford
                @brianoldford70365
                IIRC the cut-out in the bed is larger to accommodate the bevel gear that rides in the keyway. Myford may have rationalised the beds of the later PCF and non-PCF machines.
