Myford MF74
Myford MF74
Home Forums General Questions Myford MF74
  • #148482
    Neal Swarbrick
      @nealswarbrick19322
      Hi Mr Mod'
      Please move this thread to the correct "topic" area if I have posted it wrongly.
      Hi all,
      Have just joined MEW for fun times and friendship, maybe more blush
      I have just bought a Myford MF74 4" Precision Lathe with splash-back/drip-tray, steel stand, all change-wheels and sundry effects from our favourite auction site for a VERY reasonable price.
      It seems to have been doing the rounds for a few years but looks fairly good nonetheless . . . I'll be picking it next Sunday so I'll be biting me nails 'til then . . .
      Anyway, questions:
      1) Without naming names, is anyone aware of this machine and it's history? Have I bought a dog? Or is it truly a bit of a bargain with good prospects?
      2) Does anyone know of an extant manual for it? Original or good quality copy or even an on-line doc/pdf.
      3) It seems that it has the 'short' (as opposed to Very Short) cross-slide.
      Is there a major difference in dove-tail/feed-screw dimensions between that and an ML7 cross-slide? That being a lot larger/longer with lateral rather than longitudinal T-slots.
      Are the dove-tails compatible or will some machining be required?
      If the ML7 dove-tail is bigger can I get away with bulkier gib strips?
      I have also seen vague references to mod's to the cross-feed allowing for further "reach" – Can you point me to a good posting about it, please.
      4) The first job, however, is, of course, the obligatory strip-down, clean, re-paint, re-lube and assembly.
      Do you have any Must Do's and Do Not's for me?
      Am not a complete novice but it's been a good few years since I had hands on a lathe and this is certainly my first time on a Myford, and an old one at that.
      I am sure I will come up with more questions as time goes by but these few will do for now.
      Thanks in advance,
      Neal xXx
      #23228
      Neal Swarbrick
        @nealswarbrick19322
        General questions on same . . .
        #148485
        NJH
          @njh
          Hi Neal
          At the risk of an accusation of Grandmothers and Eggs you have seen THIS site I trust?
          N
          #148486
          Neal Swarbrick
            @nealswarbrick19322
            Hi N,
            Yeah, I've seen that site, thanks
            Have spent a good month looking over lathes on-line – very limited finances prevailing – and that site has proved invaluable. It was partly down to that write-up that I opted to buy the machine.
            Neal.
            #178425
            david harding 3
              @davidharding3
              Hi, I have an old mf74 which is being stripped and checked over but I have hit a problem with removing the spindle and looking for any answers please. The spindle gear is off and the grub screws are removed from the bull wheel and pulley assembly. The bullwheel rotates on the spindle but does not slide along. I assume the spindle knocks out through the chuck end split bush.Tapping the spindle produces a solid sound not just a tight thud. Any ideas please?
              Ian S C
                @iansc
                Dave, have you checked that there is not another grub screw down the hole?
                Ian S C
                #194507
                Killian Stewart
                  @killianstewart76582
                  Hi I have one of the MF74 only 500 made so very rare 1941/42 I haven't striped down so can't help there but I'm selling mine that needs restoration it takes the same Chang gears as ml7 , has a 4 pully speed change 3/4 lead screw and seems very steady with 4 bolt down front and 2 on back end
                  I've seen them for 800 + restored
                  #194541
                  Ady1
                    @ady1
                    Very solid looking bits of kit and produced at a really strange period in time, and for what reason I have ever to read anywhere
                    edit: Maybe a stop-gap for specific contracts until enough kit from the USA arrived in quantity? Atlases and south bends for example
                    They can't have been a challenge to the M series contracts since there wasn't even a leadscrew clutch, the bore was only 5/8 and the bearings were not very high end, but they really look like serious metal munchers for hobby/professional use
                    With a bit of modding one could be a friend for life
                    Edited By Ady1 on 23/06/2015 00:48:11
                    #194548
                      Posted by Ady1 on 23/06/2015 00:42:27:
                      … the bearings were not very high end …
                      Yet they apparently offered an optional high specification leadscrew
                      Very interesting. dont know
                      Ian S C
                        @iansc
                        With that date of manufacture, could they have been made for a military contract, perhaps for training workshops, or even mobile workshop use.
                        Ian S C
                        #518498
                        Ady1
                          @ady1
                          Dunno what it is about me but I keep running randomly into these things
                          Maybe they were so well made that they'll go for a couple of hundred years
                          Edited By Ady1 on 08/01/2021 19:11:51
                          #518554
                          Hopper
                            @hopper
                            There was a thread on here recently about somebody had one. Look like a nice machine. Would have been more expensive than the M-type of the day or the later ML7 so were probably well cared for.
                            #618176
                            Ady1
                              @ady1
                              ME1999-August 31 1939 advert
