Myford Dividing Plate Size
Home › Forums › General Questions › Myford Dividing Plate Size
  • #112872
    john dakin
      @johndakin59277
      Does anyone know what the correct sizes are for the Myford dividing plates, i need to know the outside dimeter of the plate, the size of the centre mounting hole,the size of the indexing holes on the various circles and the measurements and layout of the 3 screw fixing holes, any help on this please as there does not seem to be much info about on these, thank you.
      #22485
      john dakin
        @johndakin59277
        #112905
        Robbo
          @robbo
          Hi John,
          Subject to cold fingers, the plates measure as follows:
          Dia 6and 3/8th inches, thickness 1/4 inch, centre hole 5/8 inch, index holes 1/8 inch, fixing holes 5/32 inch on a PCD of 61/64 inch. Holes are all "clear" measurements.
          Index holes are countersunk both sides, fixing holes are well countersunk to sink fixing screw heads, centre hole not csk.
          On each plate there is one line of index holes in line from edge to one of the fixing holes, these are numbered with the divisions, and are what you might call the "top" of the plate. In line with these is another hole 1/4 inch dia and about 2 inch in from edge, whose purpose seems to be to indicate the numbered holes.
          Hope this helps – no doubt we will find out if I have mis-measured!
          Phil
          #113188
          john dakin
            @johndakin59277
            Thanks very much Phil your a gem, just what I needed, if anyone has a close up photograph of a Myford plate it would be good to see [email protected]
            Robbo
              @robbo
              John,
              Have emailed an image to you. PM me if it doesn't arrive.
              Phil
              #113236
              john dakin
                @johndakin59277
                Thanks Phil it arrived, I think that I could just about use that for a pattern as its very accurate
                john
                #113302
                Robbo
                  @robbo
                  I included a rule so that you could get it to scale correctly if you thought of using it like that. Given the problem of lighting flat steel surfaces for photography I think it is probably superior to a photo.
                  Phil
