Myford 254V Plus gearbox noise and vibration
Home › Forums › Manual machine tools › Myford 254V Plus gearbox noise and vibration
  • #14078
    Robert Trethewey
      @roberttrethewey
      Question from members who have experience of servicing a lathe
      #505845
      Robert Trethewey
        @roberttrethewey
        Hi: Everyone – on the 2nd of May 2019 IFoggy wrote that he'd found a small piece of iron in one of the gears of his Myford 254V Plus lathe which caused a vibration when using the lathe's back gear – I'd very much appreciate knowing how he actually found the offending piece of metal as I may have a similar problem effecting my machine to a small amount but I'd like to ensure that this doesn't develope into a real problem.
        My Myford 254V plus can be seen on http://www.ritasears.blogspot.com look at tab "R" if you're interested in seeing the rebuild of a Myford KF-MC-C milling machine which will shortly be fitted with a three axis DRO and a home built power drive on it's longitudinal table look at tab"O"
        #505870
        Chris Pearson 1
          @chrispearson1
          Are you able to measure the frequency of the vibration (against spindle speed)? That ought to give you an idea where to look.
          #505876
          Robert Trethewey
            @roberttrethewey
            Hi: Thanks for coming back to me so quickly – I don't have anything to measure the vibration. I can hear and feel a very slight knocking – this is why I looked up posts about bearing setup and adjustment thinking it was a loose bearing which could be the case as the previous owners, a technical college in London, who's engineers had done little or no maintenance since the machine was first supplied to them.
