Milling on the lathe
Home › Forums › Beginners questions › Milling on the lathe
  • #834026
    Brian John
      @brianjohn93961
      Has anybody used this type of milling attachment ? It uses a quick-change tool post which I was not initially going to buy but this looks like a good idea.
      Mini Vertical Slide 90 x 50 mm For Instant Milling Operation on Lathe Machine AU | eBay Australia
      #834032
      Diogenes
        @diogenes
        I can find a 90 x 50 mini slide on Ebay UK, but it I suspect the workholding arrangement must be different.
        Your link seems kaput..
        If it’s any help, you don’t want to ‘stack’ attachments – a milling slide is best if it is bolted straight to the cross-slide with the least number of ‘interfaces’ possible in the path between work and cutter; if that makes sense?/ you see what I mean..
        #834035
        Diogenes
          @diogenes
          ..tho’ it occurs to me (IIRC) that many m/lathes lack an easy means of attaching a slide – anything that looks like it might be subject to flexing &/or vibration won’t be a great performer..
          #834044
          John Haine
            @johnhaine32865
            ebay item no. 357225156875
            It isn’t based on a QC toolpost.  I have used something similar and it was very limiting.  Generally turns out hard to mount the work so get it in a suitable position for milling and the available work envelope is very limited.
            #834048
              The one John hain links to replaces the topslide and uses the slide sfixings so is about as rigid as you can get on a minilathe without tapping the cross slide as they don’t have tee slots.
              There are less rigid ones that are held in the toolpost rather than a tool bit and they are very flexible with a lot of overhang due to the Z bracket.
