Metrotropolitan Vicker Single phase motor
Home › Forums › Help and Assistance! (Offered or Wanted) › Metrotropolitan Vicker Single phase motor
Viewing 11 posts - 26 through 36 (of 36 total)
  • #574526
    duncan webster 1
      @duncanwebster1
      Ah I see now, the switch contacts rotate with the rotor
      #574538
        I suspect that this lady would have known about the design : **LINK**
        https://en.wikipedia.org/wiki/Dorothy_Smith_(1898-1975)
        John Haine
          @johnhaine32865
          So it turns out that this motor actually has 2 field windings, but on the rotor! There also seems to be a centrifugal switch which I guess disconnects the start winding (which will have a high resistance to get the necessary phase shift) once the motor is going. You can see why this didn't catch on – all that trouble for a 1/4hp motor! Also the windings being embedded would be difficult to cool. I think as Robert suggests this might be to wriggle out of a patent – if this is truly WW1 as initially suggested Tesla's patents would probably still be in force.
          Whatever, given the age of the windings and the need to dismantle the motor if the starter switch fails I don't think it would be a good idea to use it "in anger" but rather regard it as a museum piece.
          #574577
            This motor's construction is almost as mysterious as the Antikythera mechanism!
            Although the inverted layout works, I can only think of disadvantages, apart maybe from simplifying the centrifugal switch. Everything else feels wrong: high-maintenance and low efficiency brushes? Wouldn't powering the rotor make it bigger and hotter than need be? Isn't it easier to wind stators than rotors?
            There must be a reason. If only we could find how it was described in the MetroVic catalogue. Robert's patent avoidance suggestion sounds good to me too.
            I think it's early – are those circumferential holes for adding balance weights?  See lead lumps below.
            Edited By SillyOldDuffer on 07/12/2021 15:07:54
            #574606
            Robert Atkinson 2
              @robertatkinson2
              There are other examples of "inside out" induction motors. However most of these have the inner part with electrically connected windings stationary and the outer rotating. This means they need no brushes. A well known type is by PAPST (now EBM-PAPST). These are shaded pole types and connonly used for fans
              https://www.hermannpapst.de/the-engineer/the-most-successful-developments/the-most-successful-developments/
              Robert G8RPI.
              #574626
              John Haine
                @johnhaine32865
                …and I think PAPST made inside-out torque motors and hysteresis synchronous motors for high end tape decks?
                #574633
                V8Eng
                  @v8eng
                  If anyone wants to seriously research this motor I think the Science museum group have a large archive of Metropolitan Vickers records.
                  Edited By V8Eng on 07/12/2021 23:33:13
                  #574635
                  duncan webster 1
                    @duncanwebster1
                    Might be more appropriate to give them the motor, can't be many about
                    #574667
                    John Haine
                      @johnhaine32865
                      Best place for it, IMHO.
                      #574672
                      V8Eng
                        @v8eng
                        Too much stuff in warehouses already?
                        #574690
                        John Haine
                          @johnhaine32865
                          Probably true…
