Mercer comparator gauge repair help.
Home › Forums › Workshop Tools and Tooling › Mercer comparator gauge repair help.
  • #833473
    Graeme Seed
      @graemeseed34272
      Many thanks Pete, very informative. I’ve subscribed to his channel.
      #833476
      Graeme Seed
        @graemeseed34272
        Hi John, I’m very interested to buy, Graeme.
        #833491
        Robert Atkinson 2
          @robertatkinson2
          One reason that these instruments and their makers have disappeared is that the technology has been superceeded. One major problem with them is that there is no direct way to get an electronic output that can be used for automated measurements. Yes, you could put a camera in front of it and extract the readings. But when automatic data recording first started that was not possible.
          The alternatives are LVDTs (linear variable displacement transformers) and laser interferometry or displacement.  I’ve used both professionally and personally have an older Solartron DR600 display and DP10 (0.5um) probe. The current probes are accurate to 0.1um and repeatable to 0.05um with 0.01um resolution. I also have old Heidenhain analog LVDT and display which is very sensitive but I’ve no information on.
          Robert.
          #833503
          John Haine
            @johnhaine32865
            Graeme, I sent you a PM.
