Looks a lot like plastic
Home › Forums › General Questions › Looks a lot like plastic
  • #599009
    nigel jones 5
      @nigeljones5
      Just checking out the competition and saw this burner – nothing wrong with the burner but the white part on the end looks very much like plastic/derlin. https://www.hobbysteam.com/store/4-burner-only-120mm.html?fbclid=IwAR11W7uXh3ovgd4dpfHFmHb-g8uynmTDTDxcLXqEglVoC0iYbI2YCHFsgQU
      #28713
      nigel jones 5
        @nigeljones5
        #599010
        nigel jones 5
          @nigeljones5
          #599011
          Nigel Graham 2
            @nigelgraham2
            More likely a machineable ceramic, surely.
            #599013
              How hot would you expect that part to get, Fizzy ?
              I note the push-fit connector is not far away.
              noel shelley
                @noelshelley55608
                The tube is made of alli so don't expect too much warmth ! Noel
                #599016
                Baz
                  @baz89810
                  Why not buy yourself one and then you can play with it to your hearts delight and see first hand what the plastic looking bit is, as you are a business I am sure you can put it through the books.
                  #599034
                  John Haine
                    @johnhaine32865
                    Maybe derlin is heatproof?
                    #599037
                    DC31k
                      @dc31k
                      Is the white part not an insulator or thermal break so the heat does not transfer down the tube supplying the gas?
                      I was under the impression that in a properly functioning burner, the flame does not touch the orifice from which it emerges, so the heat transfer to the aluminium part is through the surrounding atmosphere. In that respect the aluminium is a good choice as its thermal mass, high surface area and good conductivity will keep it cool. Short of copper (not easily found in box section), what would be better?
                      #599038
                      AdrianR
                        @adrianr18614
                        It could be PTFE
