Linux – The perfect OS as long as you don’t need to actually DO anything
Home › Forums › The Tea Room › Linux – The perfect OS as long as you don’t need to actually DO anything
Viewing 10 posts - 26 through 35 (of 35 total)
  • #837830
      Fulmen
        @fulmen
        Well, it was the one recommended by a linux-capable friend. But in reality it doesn’t matter, it’s just something they use to deflect complaints. Whatever distro you run it is always the wrong one.
        I have actually gotten Mint installed so it boots properly, but unfortunately it hasn’t solved the main problem of still being linux. It is at it’s core still a command line OS with a GUI bolted on. And all software will assume you already know how to use it.
        #837924
        Fulmen
          @fulmen
          Just to address your feedback a bit:
          – No SD card so jump to network.
          Manually swapping cards has always been an annoyance, that’s why I switched to USB in the first place. And since USB worked so well I never bothered to stock up on  SD cards.
          – Windows fails, so jump to Linux.
          One computer failed, so I switched to my backup. It was running on linux so I figured I should try to get more experience with it.
          – Cura fails so jump to Octoprint, Octoprint fails so jump to VNC.
          I had a thing to print, so installing Cura seemed like the quickest fix. When that became a lot of work I figured I was better off putting that work into a better and more permanent setup. Octoprint has been on my wish list for a while.
          When this also proved to be a major undertaking I switched my primary focus to VNC so I could work from my work station.
          And to my defense this is exactly what I ended up doing once I had rebooted to Windows and updated the system. First I installed VNC, then I could work on Octoprint and the webcam solution. And except for it running on Win10 it’s everything I could have hoped for.
          As for Linux my experience always reminds me of this: https://www.youtube.com/watch?v=DvswW6M7bMo
          #837993
          Russell Eberhardt
            @russelleberhardt48058
            Installing Cura on Linux Mint is a doddle (no need for command line) Just download the appimage file from Ultimaker’s site, Right click on the file, select Properties>Permissions and click to allow executing file as program. Afterwards just clicking on the file will execute it.
            Russell
            #838065
            Fulmen
              @fulmen
              OK. I ended up going a different route so I won’t be installing Cura, but it’s good to know.
              #838115
              Fulmen
                @fulmen
                As for the source of the crashes I have come this far in analyzing the minidump:
                DRIVER_POWER_STATE_FAILURE (9f)
                A driver has failed to complete a power IRP within a specific time.
                Arguments:
                Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
                Arg2: ffffc4841ec50dc0, Physical Device Object of the stack
                Arg3: ffff92026b099680, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
                Arg4: ffffc483ef258a90, The blocked IRP
                Which wasn’t very helpful. Then I saw this:
                FAILURE_BUCKET_ID: 0x9F_3_POWER_DOWN_CH341S64_IMAGE_UsbHub3.sys
                I do have a cheap USB hub (with an integrated card reader) and an extra USB card reader plugged in, but as far as I can tell none of these use the CH341 driver. But I’ll unplug them for now and see if it makes any difference.
                Edit:
                Wow am I blind. The hub was using the UsbHub3.sys, so it’s a good bet it’s involved.
                #838836
                steveh2024
                  @steveh2024
                  I used to try out different distros  but have settled on Ubuntu and find it can do anything that Windows can do (and probably a lot more) but agree that there is a greater learning curve with Linux. Not good idea to keep switching to different distros as they all have slight differences which you then have to re-learn. Using Linux is definitely worth the effort to escape from the nagging and claws of Windows.
                  #838845
                    Fulmen
                      @fulmen
                      Oh, I’m sure I can find a way to put the blame blame on Linux either way.  😀
                      #838953
                      Adam Harris
                        @adamharris13683
                        For anyone who actually enjoys playing with Linux for CNC, I have an unused Mesa 7i76E card I bought from Mesa in California in 2017 which I am putting up for sale in the classifieds here. I never got to grips with Linux and as soon as I saw Rocketronics ELS for non-programmers I happily forgot about the idea and waited for something cheaper to turn up, which it did – the French ELS I have just bought. Anyway, if anyone is interested please PM me. I am never going to use it but I would like to get something for it to put against my foolhardy investment in the card but also in that standalone Linux computer Dell optiplex 760 (which I would include for free).
