Lathe turning speed in relation to different metals
Home › Forums › Beginners questions › Lathe turning speed in relation to different metals
  • #488558
    Chris TickTock
      @christicktock
      Hi Guys,
      Currently I am going back to machining fundamentals.
      Reason: If you don't have a grasp of these you are ill prepared.
      So OK you are told different speeds for a given diameter of say mild steel, silver steel, brass or aluminium.
      But can any one explain why it is advised to go at a given speed for a harder / softer metal.
      Chris
      #10356
      Chris TickTock
        @christicktock
        #488563
        Cabinet Enforcer
          @cabinetenforcer
          Posted by Chris TickTock on 31/07/2020 19:36:07:
          Hi Guys,
          Chris
          The "best" speed is due to the relationship between the mechanical properties of the material (shear and yield strength, Youngs modulus, etc) and the mechanism of chip formation, also often limited by the properties of the cutting tool.
          Practically speaking, it because that that is the speed that "works".
          #488564
          HOWARDT
            @howardt
            There is a lot of science involved. Basically it is how the material being cut reacts with the cutting edge of the tool. If you compare the same material with different cutting edge profiles it will give you some idea. Tool manufacturers such as Sandvik have numerous solutions and in production machines it may take numerous trials with a particular machine to get to an optimum tool life. You can search online and find many articles on the science behind it all. With small hobby machines and a single type of tool for everything much is trial and error, what works for doesn’t for another.
            #488566
            Dave Halford
              @davehalford22513
              Posted by Cabinet Enforcer on 31/07/2020 20:02:03:
              Hi Guys,
              Chris
              I would also add it's also the speed that removes the most metal in the least time at the best cost of cutting tool. They assume you have at least a Harrison 300, some tables list the HP require to achieve the speeds and full flood coolant.
              Hence Mr Wheelers question if you saw it in time.
              Nice to know for college courses but not really relevant to the man in a shed, ultimately 'it depends'
              Edited By Dave Halford on 31/07/2020 20:47:26
              #488587
              Paul Kemp
                @paulkemp46892
                "Hence Mr Wheelers question if you saw it in time."
                The mysterious disappearing post! I wondered about that as it vanished almost in front of my eyes, without trace!
                Sense and sensibilities ensuring inclusivity and diversity I guess?
                fpm is directly scalable from a Sherline to a Holbrook but that is where the similarity and theory end and why cutting speeds and feeds are recommended and not compulsory, dependant on tool material and geometry, machine rigidity, the way the work is held etc. The chances of getting a consensus on the OP question is about as likely on here as agreement on which lathe is best.
                Paul.
                #488591
                Mike Poole
                  @mikepoole82104
                  Someone has gone through the pain of testing how materials machine with different tool materials and cutting angles, clearances and speeds. They are not set in stone but provide a good start point, they will always be a compromise so feel free to deviate. If your tool fails prematurely then you have gone the wrong way, if the finish you desire is not being produced then you need to determine where your problem lays. In my experience the recommended speeds, feeds and angles are not far out. It is probably better to go with the recommendations of hobby authors than full on industrial machine recommendations.
                  #488603
                  Ady1
                    @ady1
                    On a small hobby machine it's often suck it and see
                    If you do a big piece cutting can be not very good on the outside and improves as you whittle it down
                    Not so easy to see subtle differences on a larger powerful machine because it compensates for more issues
                    On the other hand a unimat sl shows you everything, a unimat is great for showing you good tool grinding angles since you have almost no stiffness
                    Edited By Ady1 on 01/08/2020 08:02:59
                    #488605
                    Kiwi Bloke
                      @kiwibloke62605
                      I'm sure you can find more than enough explanation in books – remember them? However, in the home workshop, what works is what matters… Suck it and see.
                      #488606
                      JA
                        @ja
                        Posted by Kiwi Bloke on 01/08/2020 08:07:39:
                        Suck it and see also applies in industry. For example a lot of high temperature alloys can be machined but since very few businesses use them there is not real "knowledge". So manufacturing engineers have to find cutting speeds. The easiest way is to put a piece in a lathe………
                        JA
                        #488608
                          Posted by Paul Kemp on 31/07/2020 23:17:47:
                          Presumably removed by a moderator, as deletion of the content [by Mr Wheeler] would leave a trace.
                          I didn’t see it
                          larry phelan 1
                            @larryphelan1
                            Try Sparey,s book, still good after all this time.
                            Simple Direct No bull.wink
                            #488622
                            Nick Wheeler
                              @nickwheeler
                              Mr Wheeler did wonder where, and why, it had gone!
                              #488623
                              john halfpenny
                                @johnhalfpenny52803
                                Mr Wheeler, I thought it was incisive and excellent advice-but it disappeared.
                                #488625
                                Chris TickTock
                                  @christicktock
                                  Than you for those that answered sensibly which was at a basic level the stock materials yield and strength have most to do with book suggested speeds.
                                  I see nothing wrong with asking what others may take as obvious or just get on with it type of questions. The marriage of handed down knowledge with hands on suck and see experience is likely to produce superior results to just having a go.
                                  I am a man in the shed in no rush to go any where. Those who like being rude or have a propensity to be intolerant on this forum may be impressing a certain type whilst alienating another.
                                  Chris
                                  #488630
                                  Emgee
                                    @emgee
                                    Posted by john halfpenny on 01/08/2020 10:42:02:
                                    I also thought it was good advice although very much straight to the point, a very similar comment has been made but not in such a direct manner.
                                    Emgee
                                    #488643
                                    Dave Halford
                                      @davehalford22513
                                      Posted by Chris TickTock on 01/08/2020 11:01:16:
                                      Chris
                                      Chris,
                                      The answers to most of your general lathe questions are, as Larry suggests in Spareys book and others, perhaps Jasons and Neils 'how to' series in the mag would be more to your liking.
                                      The reason why most replies involve 'suck it and see' is that we have found out not all small lathes behave the same. I know you feel like you are missing knowledge that would make you better at turning and you are, it's what comes from trying stuff out on your machine.
                                      #488646
                                      Chris TickTock
                                        @christicktock
                                        Posted by Emgee on 01/08/2020 11:30:09:
                                        Emgee
                                        Agreed, a little diplomacy often helps.
                                        Chris
                                        #488658
                                        ChrisB
                                          @chrisb35596
                                          I find it much easier to get a good finish on a small lathe with a VFD as I can alter the speed while taking a cut. The finish will change with rpm.
                                          But as mostly said above, it's trial and error, I know there are books and recommendations etc…but I'd rather make some swarf first, and then post the results and questions on the forum, probably you will get more meaningful answers.
                                          Edited By ChrisB on 01/08/2020 15:52:27
                                          #488671
                                          larry phelan 1
                                            @larryphelan1
                                            Chris Tick Tock,
                                            I hope you did not think I was being smart or rude with my reply, this was not my intention.
                                            The reason I mentioned Sparey,s book is because, like you, I had little or no idea regarding cutting speeds/materials ect, but this book explains it all in plain terms. If it is now out of print, more,s the pity, since it,s a goldmine of information for beginners [like me ] No doubt there are many other good book available, I just never felt the need to look any further than this one since it seems to cover almost everything.
                                            No doubt others here will advise you on the subject but the speeds given by Sparey are ;
                                            Stainless Steel 50ft per min
                                            Carbon Steel 60
                                            Cast Iron,, Mild Steel Wrought Iron 80 ft per min
                                            Brass 200
                                            Aluminium and its Alloys 300.
                                            To calculate revs Cutting speed divided by quarter of work diameter= r-p-m
                                            Sorry if I sounded like a Smart-Arse, that is far from the case, I can assure you !sad
                                            #488679
                                            jann west
                                              @jannwest71382
                                              some people find the following to be helpful as a starting point for feeds and speeds: **LINK**
                                              you use a ruler, to indicate the correct speed, like so: **LINK**
                                              #488687
                                              Chris TickTock
                                                @christicktock
                                                Posted by larry phelan 1 on 01/08/2020 16:36:17:
                                                Chris Tick Tock,
                                                Carbon Steel 60
                                                Brass 200
                                                No problem, thanks for the post.
                                                Chris
                                                #488722
                                                  The problem with 'book' speeds is they don't allow for many variables – how well is your lathe adjusted? How powerful is it? How sharp is your tooling? Do you use coolant? If yes a flood or a drip or a splash with a brush? How smooth is your hand feeding? How deep a cut are you taking? Do you really know the properties of the metal you are cutting? How confident are you?
                                                  In my view, when using a smaller lathe what matters is learning the signs of the wrong speed (chatter, noises, overheating, stalling, vibration, long stringy swarf – sometimes unavoidable), and what to do about them.
                                                  Sometime speeding up or increasing the feedrate is the best solution – counterintuitive for a beginner and downright scary if you are parting off.
                                                  With so many variables any suggestions for speeds and feeds will be an approximation and the best way forward is to start from them and use your eyes, ears and fingertips (feedback through the feed handle can tell you a lot) and experiment and get to know your machine.
                                                  It may sound tedious, but I find it one of the most rewarding sides of the hobby.
                                                  John Olsen
                                                    @johnolsen79199
                                                    One thing that doesn't seem to have been mentioned is the maximum speed. The cutting edge will get hot, and the higher the speed the hotter it will get. At some speed it will get too hot and will go soft, so it will lose its edge very quickly. This can be quite noticeable, I found when boring cylinders on the Myford that there is quite a small speed difference between the cutting edge going blunt quickly and cutting all day. That was with HSS, cutting a good grade of cast iron (no hard spots) but much the same applies with carbide although the maximum speed will be higher. The heat at the cutting edge will depend on the material, for instance stainless steel is a poor conductor so will tend to get the edge hotter, while brass will conduct the heat away better, allowing a higher cutting speed.
                                                    The quality of the edge matters a lot too, thinking mainly of HSS. A really sharp edge will stay sharp longer and give a better finish. This is where a diamond hone is nice.
