Lathe alignment
Lathe alignment
Home Forums Beginners questions Lathe alignment
Viewing 25 posts - 1 through 25 (of 92 total)
  • #101353
    Novice
      @novice
      Hi all,
      I have a Myford S7 of 1962 for 7 years now and it performed well enough for me in doing small things and mostly repairs with nothing to do with model engineering. I never felt the need to check parralelisme (right word for it??) until yesterday. I read about it somewhere and I went to my shed chucked a piece of 20 mm mild steel 30 cm long and I turned the prothruding 25 cm with a light cut.After several times the cutting tool made a round bar of it and I stopped to measure. I found the diameter if the most left part of the bar being 0.3 mm smaller than neur the chuck. So, following the book, I had to raise the end of the lathe bed at the backside. So I did and things improved!! But in ordr to get the lathe turn parrallel I had to put abouy 3 mm of shimm under the beds foot.The front foot raised also that amount but at tihgtening I was worried about the amount of torque that is caused by tightening the fasteners. It is turning almost parrallel now with 0,02 mm less diam at the end. But I am still worried about the torque that is introduced in the lathe's bed.
      What do you think about this. I hope not to come in my shrd and find the bed broken or something else horrible.
      Please let me know what you think about this
      Jan
      #6392
      Novice
        @novice
        #101356
        KWIL
          @kwil
          It is not surprising that you could feel that the fasteners are tight. If you did not need to really tug at the spanner you are probably OK. Did you also look at the lathe with an engineer's level, across the shears at each end? You would easily have seen that amout of difference before you adjusted things. Where do you live? There may well be a fellow S7 owner nearby who could advise.
          #101360
          Harold Hall 1
            @haroldhall1
            Hi Jan
            Can we first get this clear, after turning the test piece it was smallest at the free end of the bar, that is farthest from the chuck holding it.
            I must say though that 250mm projecting from the chuck at 20mm diameter is too much. I would suggest no more than 100mm with a 25mm diameter bar would be better.
            You do not say on what the lathe is mounted as whilst the packing is 3mm thick much of the twisting will probably be in the mounting surface. Twisting the bed by that amount would seem very extreme.
            Turning a test piece of 250mm long by 20mm diameter one would expect some deflection so the actual situation will be worse than the amount you have measured. Do carry out the test with a shorter larger diameter bar as above.
            Harold
            #101362
            Novice
              @novice
              Hi, KWIL and Harold, thank you for your reactions.
              First of all I apologise for having you mislead a bit. The protruding end of the bar I'm using is 150mm (6&quot long NOT 250.
              Secondly I like to point out, that the shears are level (without the packing) At the tailstock side it's dead level and at the chuck's side you need 0,25 mm between the back-shear and the level (not an engineers level but a artillery level 0,3mm/m. Is's also level lenghtwise.
              The lathe is mounted on a Myford industrial cabinet on a concrete floor. the cabinet is also level in lenght and in width.
              not being happy with the situation I just removed the packing and (not having the bar removed from the chuck) I gave it another try and the diam at the end (not at the chuck but at the tailstock end) was 0,4 mm less than near to the chuck.
              The manual says the bar should be between 4 and 6" and 1" in diam.
              Maybe the 20 mm is not stif enough. In the week to come I'll try 30 mm (that's what I have in stock)
              And KWIL I live in the Netherlands. S7`s are not so wide spread here as in the UK. There is nobody in my region I know having such a machine. I don't even know someone with a lathe.
              Jan
              #101369
              Harold Hall 1
                @haroldhall1
                Your Myford cabinet will certainly not be a strong as your lathe Jan so the thickness of any packing you place under one foot will mostly be accommodated by the cabinet twisting. So if you put 3mm packing under one foot do not worry that you will be twisting the lathe by that amount.
                My Myford cabinet (not industrial) has an angle iron frame below the drip tray, I would imagine the industrial stand does also. As you have a super seven on an industrial stand, do you not have jacking screws at each foot. See my website here for an example Photograph 1
                I Think you are saying that the lathe is level at the tailstock but requires a piece of packing, 0.25mm, under the rear of the level to make it read level at the chuck end, that is far too much. It is getting late so I may be getting it wrong, but I think that error is at odds with the error you are getting in the test piece. I will think more about it in the morning.
                I know I will be shot down for saying this but being level is not vital, not being twisted is the important requirement, if you needed 0.25mm at both ends that would be almost as good. In any case, a very small twist can sometimes be needed to offset manufacturing errors in the lathe itself.
                Harold
                #101373
                Terryd
                  @terryd72465
                  Posted by Harold Hall 1 on 19/10/2012 22:46:00:
                  Harold
                  Hear Hear, It is not neccessary to be level, ask those Navy Engineer making repair parts in a pitching sea. Twist is what matters
                  Terry
                  #101375
                  Phil P
                    @philp
                    I will second that.
                    As long as the bed twist is under control, being level is not that important.
                    I have mine set slightly high at the tailstock end, the reason being that the coolant drains from the tray a lot better.
                    Phil
                    #101377
                    blowlamp
                      @blowlamp
                      So as not to confuse Jan and others reading this.
                      When it comes to machine tools, the common term of being 'level' is used to describe the sliding and working surfaces as being planar, rather than purely horizontal or vertical. That is, the machine is installed without twist so as to maintain factory alignments.
                      The simplest way to do this is with an engineer's level.
                      Martin.
                      Edited By blowlamp on 20/10/2012 00:21:04
                      Edited By blowlamp on 20/10/2012 00:22:44
                      #101389
                      Harold Hall 1
                        @haroldhall1
                        Unfortunately, Martin, 99 percent of lathe owners, almost certainly more, don't know that, ask a builder who has a lathe. I do agree though that if an engineers level is available It is not only the simplest method, it is by far the quickest, especially if the lathe has jacking screws for its mounting. But even then a test piece must be turned so as final adjustments can be made if necessary, so that the lathe turns parallel. Also, engineers levels are very expensive in most peoples estimation, OK, they can be had for around £60 so I am told. Even so, many have purchased a machine and then found they do not have the cash for the essential extras, let alone a spirit level. I know, I've been there, which is why I got so much into making workshop tools.
                        Now to Jan's problem. As there would seem to be some conflicting facts in the data we have, in that if the bed is lower at the rear at the chuck end, especially by the amount given, then the test piece should be larger at the free end, not smaller.
                        I would suggest therefore Jan, that you forget the spirit level at this stage and make adjustments purely on the basis of the result of turning a test piece.
                        Harold
                        #101395
                        blowlamp
                          @blowlamp
                          As I seen Jan's problem.
                          Jan seems to have tried leveling his lathe by twisting the bed in accordance with measurements he has obtained from turning a test piece. Whilst this is a perfectly good method with a factory fresh machine, the same can not be said once that lathe has been either well used or interfered with by others.
                          The whole purpose of the machine level is to allow the lathe bed to be installed without stresses and warpage being introduced to it. Once this condition is achieved, its performance can be tweaked by very small adjustments to the level until parts are turned parallel.
                          If the headstock has shifted through wear or abuse etc, or the bed is worn, then this should be seen to first.
                          From Jan's description, it would seem that he is having to put a lot of twist into the lathe bed in an effort to counteract its inherent (at the moment) tendency to turn a taper and this can not be right.
                          Martin.
                          #101398
                          Tony Pratt 1
                            @tonypratt1
                            Hi Jan, have you got a copy of the S7 manual? if not it is a good idea to get one and well worth the cost! I have set my S7 several times using the cut and try method described in the Myford manual with no problem. don't worry about how much shim you need as the stand etc is only a welded box and cannot be expected to be a reference surface. When the lathe is cutting parallel the lathe bed isn't twisted. Obviously a used lathe will be worn to a certain extent so you will have to get the best out of it you can.
                            Tony
                            #101402
                            KWIL
                              @kwil
                              I am glad to have Martin (Blowlamp) agreeing with the use of a "level", there was NO suggestion on my part that the lathe in question should be set level, as others also agree. There is of course the possibility that at some time the headstock has been removed and this can be another source of non parallel turning.
                              #101450
                              speelwerk
                                @speelwerk
                                I can state that it is possible to align a Myford lathe (made in a country where they drive on the left side of the road) accurately in the Netherlands.
                                A slant bed lathe, like the Dutch made Ergonomic, proves the point that as long as the lathe bed is not twisted it will turn parallel, however it is a curious experience when you are standing behind it for the first time.
                                Niko.
                                #101498
                                Terryd
                                  @terryd72465
                                  Posted by KWIL on 20/10/2012 11:08:43:
                                  I see now Kwil,
                                  you mean 'without twist' as opposed to horizontal. Thanks for the clarification I use 'level' to mean horizontal, or a position on a scale such as 'level of government', or position "on the upper level", hence the confusion.
                                  Terry
                                  #101676
                                  Rufus Roughcut
                                    @rufusroughcut
                                    Hi Jan/Gents
                                    For info to those whom may be new to the sport of "measuring twice and cutting once"
                                    I've just refurbed a ML7 (1954) once rebuilt I found a similar thing, when I checked the center alighnment from Chuck Spindle to Tailstock Spindle, these where out of line and hence the tapering, I corrected this with the use of two small capacity MT2 tapered chucks (0-10mm opening) one inserted in each spindle both with a small sewing needle in, brought the two points almost together and adjusted the tailstock adjustment screws to compensate which solved the mis-alignment cross the bed, the then problem I encountered was height needle to needle which appeared to be 0.009" low at the tailstock, I parted and shimmed the front edge of the tailstock between the foot plate section and spindle casting with two 4mm wide strips cut from an old beer can which 0.0045" thick across the whole width of the tailstock, I then rechecked ( sherlockholmes magnifying glass and a small torch) with the needles by moving the tailstock backwards at intervals until tailstock was fully extended, at fully extended the needles just started to glance tailstock downwards (don't know how to quantify this deflection let alone measure it.
                                    Next I re-intalled the chuck and with a piece of 5/8" barstock 18" long (already centered at both ends) fitted between chuck and tailstock dead center. I layout blued the bar down the surface nearest me, traveresed the saddle to the chuck end, with a ready centered cutting tool (on this occasion a radius ended one), I advanced the cross slide in until the tool tip barely touched the bar I then manualy rotated the bar backward and adjusted the tool in until it scuffed the bar surface with the saddle being engaged to the leadscrew, I then manualy turned the lead screw hand wheel sliding the saddle and in turn the cutting tool along the surface of the bar, which I felt at the points of bed mis-alignment the tool would attempt to deflect the bar or score deeply into it and at these points the distortion could be marked for accurate measurement, fortunately none of these deflections or scoring occured, when I reached the tailstock end of the bar I manualy turned the chuck backwards to see a similar scuff to the one at the chuck end and was satisfied that all was ok.
                                    It's worth noting that I had initialy when re-fitting the head stock squared this by fitting the 7" back plate and using a set square verticaly up the plate to the bed surface and across the bedway to the plate, Also I have not yet required a spirit level nor wasted a bit of bar stock (which may come later when I plug it in).
                                    I hope this will help with setting up without the need for expensive kit and complex three dimesional Trig
                                    Bazza
                                    #101692
                                    MICHAEL WILLIAMS
                                      @michaelwilliams41215
                                      Any Myford lathe bed that needs twisting by more than a couple of thou on any corner is completely wrecked and needs regrinding .
                                      Most common cause of turning taper on Seven series lathes is that the spindle bearings are out of adjustment – nothing to do with bed at all .
                                      #101765
                                      Rufus Roughcut
                                        @rufusroughcut
                                        Hi Gents
                                        Correct me If I'm wrong, but If you re-grind the surfaces of the bed dose that then not require all the associated equipment Travelling on the bed to be then re-aligned, new gib strips fitted etc as the new lesser bed wil undoutedly make al the associated equipment looser in contact of the beds surfaces.
                                        and Also am I right in that if you require to make a deliberate taper, then you set over the tailstock center nearer to the cutting tool for a taper reduction to the tailstock and conversly set over the tailstock away from the cutting tool to taper reduction at the headstock end using the tailstock alignment screw and the gradutated tailstock plate.
                                        Bazza
                                        #103339
                                        Novice
                                          @novice
                                          Hi all,
                                          I like to thank everyone who has been thinking and writing about my problem.
                                          Having placed several pieces of thin metal under the back foot of the lathe's end (<2 mm) and some shimmimg under the front foot on the left it is now possible to turn a lenght of 150 mm and 30 mm diam mild steel parrallel minus 0,05 mm diam at the end.
                                          This is fine enough for me and beside this I can keep it in mind when turning longer pieces. (seldom)
                                          Thank you again and enjoy making chips!!
                                          Jan
                                          #103352
                                          Sam Stones
                                            @samstones42903
                                            I tend to cringe when I think of what can happen when cutting a (long) length of a small diameter bar which is sticking out of the chuck unsupported.smile o
                                            Therefore, I think it’s worth noting that for a round bar protruding from the lathe chuck and unsupported at the tailstock end (ie. cantilevered), it’s resistance to bending is related to the fourth power of its diameter and the third power of its protruding length.
                                            In other words, for the same applied (cutting) load, a 15mm diameter bar will deflect (bend) 16 times more than a 30mm diameter bar.
                                            Likewise, a bar protruding 200mm from the chuck will deflect (bend) 8 times more than a 100mm bar when subjected to the same load.
                                            So keep this in mind whether you are running tests or making something more important.
                                            Regards to all,
                                            Sam
                                            Edited By Sam Stones on 10/11/2012 22:20:39
                                            #115737
                                              This topic is, I think, worth keeping alive
                                              So; here for your delectation and delight …
                                              Most important; he gives a link to Mr. King's patent.
                                              P.S. Mr. King's son is still active in scraping, and acknowledged as an authority.
                                              Edited By Michael Gilligan on 31/03/2013 11:36:39
                                              #115740
                                              Tony Pratt 1
                                                @tonypratt1
                                                The bottom line is you want your lathe to turn parallel? If so follow the Myford manual to achieve the desired result, it works so why re invent the wheel? If the bed is worn you will need to decide whether to get it re ground or live with the inaccuracies. Your work will follow the machines wear patterns.
                                                Tony
                                                #115743
                                                blowlamp
                                                  @blowlamp
                                                  Yes, Graham – any more boat analogies and this topic's sunk.
                                                  Martin.
                                                  #115744
                                                  Roderick Jenkins
                                                    @roderickjenkins93242
                                                    Gray,
                                                    At the risk of inflaming the argument, I think that the ship analogy is to demonstrate your point that the lathe can be aligned yet does not have to be level with the earth. The point that seems to be difficult to get across is that when a spirit level is used across the shears of a lathe, the bubble does not have to be in the middle but it does have to be in the same position at both ends of the bed and for this you really need a precision level with graduations on the vial.
                                                    I think quite a few very good locos have been made on shipboard lathes.
                                                    regards,
                                                    Rod
                                                    #115746
                                                      Sorry folks … have I offended someone ??
                                                      I thought people might be interested in Mr. King's device
