Joining the seam of a rolled boiler
Home › Forums › Locomotives › Joining the seam of a rolled boiler
  • #831326
    David K
      @davidk77137
      I believe there is a dove tail method but this would be  too difficult for me.
      My preferred method would be to use a jointing strip to cover the butt join and solder in place.
      My question is , is there a formula to say how wide the joint strip should be and how many
      rivets should be used for a given length of tube.
      #831358
      Thor 🇳🇴
        @thor
        Hi David,
        Is it something like this  or this you are looking for?
        Thor
        #831360
        bernard towers
          @bernardtowers37738
          I think the rivets are there to hold in place for soldering.
          #831361
            Best to speak with your boiler inspector as to what he will accept due to the change in design. Also the strength of the barrel usually gets derated for a joint so check the material is still thick enough.
            #831367
            David K
              @davidk77137
              My boiler is quite small 3 3/4” diameter and 9” long.  I am not a member of any club so have done
              some searching and I will approach my local club and see if there is a boiler inspector.
              #831368
              David K
                @davidk77137
                On Thor 🇳🇴 Said:
                Hi David,
                Thor
                Thank you i will have a read through those
                #831386
                duncan webster 1
                  @duncanwebster1
                  Rule of thumb is lap 3 times plate thickness, and allow a factor of 0.8 for joint efficiency. Rivets are only to hold it together whilst silver soldering, as few as possible and don’t hammer the up tight, the solder has to bd able to wick through
                  #831404
                  Brian Baker 2
                    @brianbaker2
                    Greetings David,  speaking as a boiler inspector, it is a great joy to see someone making a boiler, rather than purchasing a finished one.  Well done for having a go.
                    I think your question has mostly been answered, Duncan has good suggestions.
                    However, I much prefer to see butt straps on the outside of a boiler when ever possible.  Then, there is no doubt they are there, and they are easier to produce, and inspect.
                    God luck with your efforts.
                    Brian B
                    #831416
                    noel shelley
                      @noelshelley55608
                      For a small boiler why are you using sheet copper – rather than drawn tube ? Do you have enough heat and equipment to properly silver solder this sort of size – many a potentially good boiler has been ruined by the lack of enough heat ?
                      The answer to your question depends on the plate thickness and also the working pressure. The calculations need to be done to arrive at the right plate thickness and there are many books that will give the formula – for a butt strap joint you will reduce the pressure by 0.8. I take it you are designing the boiler not using a published design ? Even for private use I would strongly advise you to join a club and speak to the boiler inspector, you will get all the help and advice you need and even for private use you will know it is safe ! Good Luck.  Noel.
                      #831432
                      Nigel Bennett
                        @nigelbennett69913
                        The FMES Website offers some useful advice on boiler design. You could do a lot worse than look at this:
                        https://fmes.org.uk/wp-content/uploads/2025/04/Boiler-design-calculations.pdf
                        #831469
                        David K
                          @davidk77137
                          I am purchasing a boiler kit from a reputable dealer , they have advised me that tube of the size needed
                          is no longer available so it will be supplied as flat plate. They have offered to roll it for me but I will be doing the soldering.
                          I want to make the boiler myself , I may make mistakes , I may not , at the moment I am reading and watching
                          videos to try and build my confidence.
                          I am sure to be asking questions so thank you for the replies , appreciated.
                          #831470
                          David K
                            @davidk77137
                            Thanks for the link Nigel , i will read through it .
                          Home › Forums › Locomotives › Topics
