From MEW 231:
J-B Weld
The original ‘J-B Weld’ is a steel reinforced two-part epoxy with a tensile strength of 3960 PSI. It is slow setting (around 25 minutes) and taking about a day to fully cure as you might expect from their highest strength epoxy. It can withstand temperatures of up to 550 Fahrenheit (287 Celcius) making it suitable for repairs subject to very demanding conditions. It can be drilled and tapped, and one well-known use of it is repairing cracked castings, even cylinder blocks.
J-B Weld is often mentioned on the http://www.model-engineer.co.uk forum because of its high-strength and high temperature performance, but it seems many of us are less familiar with other products under the JB weld umbrella. Here are some of their other adhesives:
KwikWeld is the fast-setting version of the original steel-loaded epoxy. Still with a strength quoted as 2424 PSI, it sets in six minutes and cures in 4-6 hours. It can handle boiling temperatures, but not superheated steam. Kwik Weld is also available in a dual-barrel syringe for convenience in use.
ClearWeld is another dual syringe epoxy that sets in just five minutes but needs an overnight cure. Its strength is between the other two epoxies, but use the steel-loaded types if you want temperature resistance.`
Perma-Lock is a thread locking compound, available in high-strength and medium strength formulations. The medium strength type can be dis-assembled with hand tools but the high-strength version requires the application of heat as well.
J-B Weld Clear Silicone sealant and adhesive and Ultimate Black gasket maker and sealant are high performance 100% silicone room-temperature vulcanising sealants.
