ignition coils
ignition coils
Home › Forums › General Questions › ignition coils
  • #22342
    Dougie Swan
      @dougieswan43463
      #104586
      Dougie Swan
        @dougieswan43463
        Can anyone help with information on a supplier of ignition coils, either 6 or 12v
        Thanks
        Dougie
        #104595
          Minimag will do a small coil and also a box of tricks so you can trip it with a Hall Effect sensor.
          If you do go with the Galloway then the ignitor needs a low tension coil which can be obtained from an old strip light fitting.
          The CDI units from S&S also get good reports, again these are Hall effect triggered
          You can also build one with a small motorbike coil sourced from e-bay, these can also be made to make a buzz coil ignition if that is what the engine calls for.
          J
          #104597
          mick
            @mick65121
            Try your local motor cycle repair workshop. I got a small set of points and a coil with condenser attached for £25.
            #104613
            Grizzly bear
              @grizzlybear
              Hi Dougie, I purchased two off ebay, different sellers. The H.T. coils were 12v & used, but OK.
              Regards Bear..
              #104674
              Ian S C
                @iansc
                Dougie, I believe there is a system used these days (I'v not come across it), that uses individual coils for each spark plugs, there is a bit about them on some other web site. Ian S C
                #104676
                Anonymous
                  High performance cars, especially racing cars, have been using on plug coils for some years. It saves the complication of a high-voltage distributor and is better for EMC.
                  #104679
                    The on plug coils do look totally out of place on a old hit and miss type engine, almost as bad as having a full size car coil on displayface 14
                    J
                    #104788
                    Ian S C
                      @iansc
                      The on plug coil, would not need to be on the plug, it could be hiden, say in a dummy magneto. Ian S C
