Horizontal spindle slop?
Home Forums Beginners questions Horizontal spindle slop?
  • #203334
    dave1888
      @dave1888
      I have a wee bit play on the spindle, it moves back and forth by about 2mm. I assume this is not supposed to happen?
      #7787
      dave1888
        @dave1888
        #203335
        Bazyle
          @bazyle
          No. What machine is it? We might be able to give you instructions on how to fix it.
          #203337
          dave1888
            @dave1888
            I should have thought of that, Its a ML7.
            #203348
            KWIL
              @kwil
              Spindle set up covered in the ML7 Handbook?
              #203352
              Ady1
                @ady1
                Thrust bearing type issue, 2mm is a lot.
                #203356
                Robbo
                  @robbo
                  Spindle end thrust adjustment is made by the threaded collar at the end of the spindle, just inboard of the gearwheel at the left hand end.
                  This is locked by a socket set screw (grub screw).  Loosen this and tighten the collar to take up the play. There is a copper pad under the set screw to protect the spindle threads, so it may be tight.
                  If this doesn't do the trick then it's probably the thrust bearing at fault.
                  Edited By Robbo on 06/09/2015 19:45:55
                  Edited By Robbo on 06/09/2015 19:46:30
                  #203357
                  Mike Poole
                    @mikepoole82104
                    The end float is adjusted by the screwed collar on the left end of the spindle, it may be worth a little investigation as 2mm is quite a lot to suddenly appear, it may simply be the locking screw for the collar has come loose and allowed the collar to move.
                    #203864
                    dave1888
                      @dave1888
                      Thanks for the reply's Guys, I tightened the screw collar all nice and tight now.
