Home Made Lathe, Safe?
Home › Forums › Manual machine tools › Home Made Lathe, Safe?
Viewing 25 posts - 1 through 25 (of 25 total)
  • #565220
    Pete.
      @pete-2
      Every now and then I see something, and just don't have words to describe.
      The bolts coming out the chuck look like a medieval torture device.
      I don't mean to be unkind, but this just looks flat out dangerous.
      Pete.
        @pete-2
        Ebay Find
        #565222
          At the current bid of £10 someone would probably get a bargain
          … as long as they render it down to a collection of components !!
          jimmy b
            @jimmyb
            Words fail me!
            Jim
            #565226
            Ady1
              @ady1
              Looks fine to me
              #565230
              Anonymous
                It's a box chuck, albeit larger than normal. Box chucks are standard accessories for clockmakers and instrument lathes.
                #565234
                  I should think it would be OK to free hob a few gear ondevil
                  #565235
                  Ian Parkin
                    @ianparkin39383
                    Interesting use of a variable speed on a single phase induction motor too.
                    #565237
                    Rob McSweeney
                      @robmcsweeney81205
                      Posted by Michael Gilligan on 02/10/2021 17:33:24:
                      Seller has set a reserve "to cover the cost of components" which suggests that – a. buying it as a source of parts won't be an economic proposition, and b. he won't find a buyer.
                      #565239
                      Dave Halford
                        @davehalford22513
                        Posted by Ian Parkin on 02/10/2021 18:34:56:
                        There's probably a trigger off a mains drill somewhere
                        #565240
                        Ady1
                          @ady1
                          I like the spindle flywheel counterweight
                          #565286
                          larry phelan 1
                            @larryphelan1
                            At least it,s Made in England. Can,t be that bad.
                            #565287
                            Tony Pratt 1
                              @tonypratt1
                              Vibration free at 2950 rpm, currently 2 bids maybe sailors looking for a boat anchor?wink 2
                              Tony
                              #565289
                              Baz
                                @baz89810
                                Only thing that puts me off is collection from Kilmarnock, can’t get any fuel to get there!
                                #565319
                                Peter Cook 6
                                  @petercook6
                                  Not sure that's an induction motor as its rated at 2950 rpm. More likely to be a universal brushed motor and the speed controller is probably one of these
                                  Edited By JasonB on 03/10/2021 13:07:25
                                  #565322
                                  John Haine
                                    @johnhaine32865
                                    They don't use universal motors on grinders because of the risk of overspeed and I can imagine a cheap grinder using an induction motor quoting its speed as 2950, synchronous speed being 3000 on 50hz.
                                    #565329
                                    noel shelley
                                      @noelshelley55608
                                      John, Syncronous speed 3000rpm 50hz, slip and losses =2850rpm(or so) for a 2pole motor.on load.Noel.
                                      #565333
                                      Peter Cook 6
                                        @petercook6
                                        John, Noel – the motor is clearly marked 60Hz 240V, and if you look at the closeup of the speed controller, inside the red box it looks like the one I linked to.
                                        But I must confess I haven't tried my controller ( used for an old electric drill) on an induction motor. I wouldn't expect it to work.
                                        #565337
                                          Posted by Peter Cook 6 on 03/10/2021 13:04:56:
                                          Presumably the link that Jason removed [see Code of Conduct]
                                          John Haine
                                            @johnhaine32865
                                            Ah, only looked at the photos on my phone, didn't see the motor plate. But a 240V 60Hz motor in the UK? Where did that come from? I just assumed that the 2950rpm was a bit of typical specmanship. I can imagine that the horrible induction motors used in cheap grinders would "speed control" down to 0 rpm run off one of those controllers, and up to max, just not very linear!!
                                            Edited By John Haine on 03/10/2021 13:47:49
                                            #565345
                                            Dalboy
                                              @dalboy
                                              We had a Black museum when I was at work of some of the things people did to power tool this should have been in that
                                              #565347
                                              Peter Cook 6
                                                @petercook6
                                                #565391
                                                  Well … it sold for £12.50 so we don’t need to worry any more
                                                  [ until the proud new owner turns-up on the forum ]
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    A bench grinder for £12.50 sounds like a bargain.
                                                    Definitely one for the DIYer's Black Museum, to my mind.
                                                    Wonder how well the Headstock is aligned to the Bed? With difficulty?
                                                    Maybe a sow's ear waiting to be changed into something better, but will take a lot of work and time to become a silk purse or anything approaching it.
                                                    But it is a starting point for a budding machinist to gain experience
                                                    Howard.
                                                    #565457
                                                    Brian John
                                                      @brianjohn93961
                                                      What…no milling attachment ?
