Help needed with Gas fired boiler
Home › Forums › General Questions › Help needed with Gas fired boiler
  • #22489
    Tom Dixon 1
      @tomdixon1
      Information sought about the sizing of burners
      #112995
      Tom Dixon 1
        @tomdixon1
        Dear All,
        I am looking for advice on what size gas nozzles would be required for a gas fired boiler for a friend's 3 1/2 inch single fairlie.
        The plan is to follow what a gentleman in Finland has done and use a simple to make boiler that looks quite like a Lancashire type with two flues.
        http://animato.medw.co.uk/3003/060v.html
        The cylinders are 1.5 inch bore by 2 inch stroke.
        Tom
        #113028
        CuP Alloys
          @cupalloys
          Hi Tom
          Sievert produce a range of propane/air burners that generate from 0.25kw to 86kw running off standard propane bottles. One of these should give you the output you require. See the website for details.
          Alternatively if you want a ribbon-type burner try birmingham burner ltd
          best wishes
          keith
