Hegner help!
Hegner help!
Home Forums Manual machine tools Hegner help!
  • #11917
    Cornish Jack
      @cornishjack
      #89092
      Cornish Jack
        @cornishjack
        G'day all.
        I have a Hegner scroll saw which hasn't been used for a few years. Needed to do some 'brown stuff' cutting and purchased a couple of packs of Sandvik blades. So far, I have broken SIX of them and not yet cut any wood!!frown The blades snap each time on powering up the machine. Has anyone any thoughts on possible remedies. I have used the saw in the past with no problems and the blade attachments are pretty basic. The blades are metal cutting but, since they haven't actually come into contact with anything, I don't see that as an issue.
        TIA
        Rgds
        Bill
        #89094
        Keith Long
          @keithlong89920
          Bill
          Just a thought, have you checked that the top arm is free to move over the same stroke length as the lower – sounds as though the blade is getting seriously over tensioned somewhere in the stroke.
          Can you wind it through a stroke or two by hand rather than applying power straight off to see if there is any binding?
          Keith
          #89095
          Martin W
            @martinw
            Bill
            You say that you have used this to cut brown stuff in the past, with the same type or similar blades, with no problems. As you say that you are using the same or the same type of blades then has the return arm mechanism become too stiff or slack after lack of use or has it had a knock and become misaligned somehow.
            If the return arm/spring is not maintaining tension on the blade then it is possible that the blade is becoming loose at some point in the cycle and the system is snatching the blade tight causing it to fail. If too tight then the blade will be over tensioned with the same result. Does the return arm have free movement for the complete cycle of the blade movement, is there a stop and if so is this adjustable to accommodate various blade lengths?
            Just a few ramblings smileywhile I await my instructions from SWMBO for the afternoon's activitiescheeky.
            Martin
            Edited By Martin W on 14/04/2012 12:39:43
            #89102
            Cornish Jack
              @cornishjack
              Thank you Keith and Martin.
              Never really had a close look at the 'workings' but have assumed ("Don't assume, CHECK!&quot that the return arm is the top one and the drive is direct to the lower attachment. If so, the top arm APPEARS to be free to move and the blade tension adjuster has been set to give a nice 'ping' (technical term!) when tapped. The basic principle of these things is such that I wouldn't have expected much to go wrong. I don't have a handbook for it (bought 2ndhand) so don't have a reference for problem areas. The blade holders are rectangular steel clamps which have 'wedges' to seat on the ends of the arms. Possibly I'm clamping the blades slightly off vertical and inducing stress? Will try again.
              Rgds
              Bill
              #89106
              KWIL
                @kwil
                Go to Hegner UK website, there are illustrated parts breakdown diags that may help.
                http://www.hegner.co.uk
                #89112
                Cornish Jack
                  @cornishjack
                  Thank you KWIL. That could be most useful. Just an update – I have at last managed to cut wood again!!surprise No idea what caused the improvement, although I stripped the main bits, oiled the bearings and took great care lining up the blades in the clamps. Still managed to break two more blades but that particular job has been completedsmiley
                  Thanks to all
                  Rgds
                  Bill
