Glass/metal joining?
Home › Forums › General Questions › Glass/metal joining?
Viewing 21 posts - 1 through 21 (of 21 total)
  • #124173
    Cornish Jack
      @cornishjack
      G'day all.
      I'm messing about trying to construct a hot air engine, using a glass test tube as the displacer and mounting it in a brass or copper flange base for attachment to the central support. Has anyone any proven methods for making heat resistant joins between these materials, please? A similar join, between a brass flange and copper tube for the power cylinder, I'm considering soldering … but, soft or silver???
      Any suggestions appreciated. TIA
      Rgds
      Bill
      #22701
      Cornish Jack
        @cornishjack
        #124174
        Peter G. Shaw
          @peterg-shaw75338
          My oven door has a glass panel glued onto a formed metal flange on the inner panel. I have successfully used RTK "High Temperature Adhesive and Sealant" from Intek Adhesives for this purpose. It is expensive though, £18-66 this time last year for a normal sized cartridge – and it doesn't appear to keep. Also, to carry the weight of glass, which I imagine is considerably heavier than for your purpose, the adhesive had to be about 2mm thick.
          Depending on the temperature range expected, I wonder of a normal temperature rating silicone adhesive would be suitable.
          Usual disclaimer.
          Peter G. Shaw
          #124177
          jason udall
            @jasonudall57142
            If , as I think you mean the testube is the displacer cylinder not displacer..and the closed end to be the hot end….The open end is usually “cold”..the point is that glass allows you to keep the two ends at maximum temperature difference.
            In any case o rings are often used to provide the seal..epoxy is some times used as an alternative
            #124180
            Jens Eirik Skogstad 1
              @jenseirikskogstad1
              You can use clue for windscreen for vehicle if the parts is not to be dismantled in future. The clue is very strong to hold the glass and metall togheter.
              #124215
              Ian S C
                @iansc
                I'v put a question on another web site, to someone who builds your type of motor, well see what he comes up with. Ian S C
                #124217
                Cornish Jack
                  @cornishjack
                  Peter, Jason, Jens and Ian, thank you all.
                  Peter – RTK sounds as though it might be good.
                  Jason – yes, you're correct – certainly temperature differential end-to-end but even so, the cool end is still quite warm!
                  Jens – yes, I had considered that until I remembered my late sister's Ford rear side window which was glued to the opener … and disappeared with no warning while en-route!!angry
                  Ian – would much appreciate that.
                  Rgds
                  Bill
                  #124257
                  Hopper
                    @hopper
                    Jan Ridders makes a lot of these glass-tube Stirlings.
                    His drawings call for silicone glue to glue the displacer on to an aluminium plug that goes screws on to the connecting rod. There is a groove in the plug so I would assume fill the groove with silicone glue or high temp silicone if you want to be sure.
                    To secure his glass displacer cylinder to its aluminum flange, he uses a groove ofr step in the flange and a rubber o-ring that is compressed when the flange bolts are tightened. If you wanted to use glue instead, I guess you could use high temp epoxy. That end of a glass displacer or cylinder is not going to get madly hot.
                    Take a look at Jan Ridders's website for more ideas. He is happy to email you plans etc.
                    #124270
                    John Haine
                      @johnhaine32865
                      Search "glass – metal seals" on Wikipedia. Common problem making vacuum tubes.
                      #124289
                      Ian S C
                        @iansc
                        I meant to say last night, E-mail Jan Ridders, from what I'v heard from others he is only too glad to pass on information on hot air motors, or any other of his models, but I see Hopper has got there first, thanks. Ian S C
                        #124292
                        Cornish Jack
                          @cornishjack
                          Hopper, JH and Ian – thank you. I do have one of Jan Ridders's plans so will dig it out and check.
                          Rgds
                          Bill
                          #124488
                          Phil Whitley
                            @philwhitley94135
                            Google Sikaflex, and see if it will meet the temperature range, I have fitted windscreens with this stuff (volvo estate) and they don't budge!
                            Phil.
                            #124526
                            David Jupp
                              @davidjupp51506
                              If you are feeeling adventurous, do a web search on 'housekeeper joint'.
                              #124536
                              Cornish Jack
                                @cornishjack
                                Thank you Phil and David, good possibilities and David's suggestion might be very helpful with the arthritis!!smileythumbs up
                                For anyone else similarly interested in joining things to things, the loctite site **LINK** could be useful. I think I may well give Loctite Glass a whirl.
                                Rgds
                                Bill
                                #124542
                                Gordon W
                                  @gordonw
                                  An old way to seal glass / metal was Sodium Silicate (water glass ) It is used in wood stoves as seal glue and glass fixing. It certainly makes a good high temp. joint, but not sure of mechanical strength.
                                  #124548
                                  MICHAEL WILLIAMS
                                    @michaelwilliams41215
                                    Strain gauge cement .
                                    #124611
                                    Cornish Jack
                                      @cornishjack
                                      Thank you, Gordon and M W.
                                      Update – Have now joined the brass flange and test tube – two methods; initially used super glue (common or garden variety) with the tube just resting in place on a polythene 'underlay'. Once that had set, I mixed up some Araldite 2-part and 'filleted' the join. Appears to be a solid join but temperature resistance remains to be seen.
                                      The brass/copper join was done to make allowance for my total lack of expertise! – brass flange and tube end were coated with thick flux 'ointment' and positioned correctly (inverted) on a suitably sized bolt held in the vice. The top (as positioned) side of the flange was then generously covered with Fry's solder paste. Butane torch applied to the copper tube until the 'witches' brew' bubbled and then left to cool. Result: the neatest solder join ever … for me!!smileythumbs up
                                      Now need to 'pickle the solder joint and intending to use Citric acid. Should be able to get crystals at local chemist but what is the ratio of crystals/powder to water for 'pickling'. please?
                                      Rgds
                                      Bill
                                      #124654
                                      Sub Mandrel
                                        @submandrel
                                        Hi Bill,
                                        Citric is good for cleaning off silver solder flux. The various fry's fluxes seem to come off with plenty of water and detergent. Quite dilute citric will clean the brass/copper of surface oxide where teh flux wasn't (if you get my drift) nicely though.
                                        frank brown
                                          @frankbrown22225
                                          High temperature silicon sealant is used to seal the joints in wood burning stove flues. Its very cheap. warning its also very fluid and will run and drip and is "very soft and flexible " when its cured.
                                          Frank
                                          #124691
                                          Cornish Jack
                                            @cornishjack
                                            Thank you, Neil and Frank.
                                            I've just finished washing off the pickle and the tube certainly looks nice and clean (the non-soldered bits). I made up a solution with 2 heaped teaspoonsful of crystals with about a quarter pint of water. Seems to work OK.
                                            I have a couple more of these things to make up so will probably try at least one of the suggestions for the next one.
                                            Thanks to all who replied
                                            Rgds
                                            Bill
                                            #124804
                                            Ian S C
                                              @iansc
                                              Keep your used citric acid in a screw top jar if only using small amounts, with larger amounts, like a bucket full, put a lid on it, and as it evaporates you just add a bit of water, it lasts for ages, and its safe to flush down the drain when you'r finished with it. Ian S C
