getting there….. now for the slide valves
Home Forums Beginners questions getting there….. now for the slide valves
  • #5929
    michael burton 1
      @michaelburton1
      #84090
      michael burton 1
        @michaelburton1
        hi all when machining the slide valves is it the nut that holds them against the cylinder face? i will be ordering them this week just would like to know before i start the machining as im going to have to change a few measurements due to the previous builders positioning off the steam ports.
        thanks to you all once again much obliged
        #84092
        Terry Lane
          @terrylane
          No, the nut should be free to move in it’s slot – the valve should be held to the port face by the pressure difference between the steam and exhaust cavity sides.
          #84097
            AS tel says you want a few thou end play so the nut won’t hold the puck off line and a bit more clearance so the puck can lift off the valve face to let any condensate out of the cylinder and prevent hydralic lock.
            J
            #84117
            michael burton 1
              @michaelburton1
              thanks guys
              mike
              #84126
              mgj
                @mgj
                You want the absolute minimum of clearance, while allowing the slide valve to move vertically, as the others have said. Excess clearance = lost motion and less precise timing (as does poor dimensioning). I worked to .001 plus the calculated allowance for steam at operating temp for expansion, because it mustn’t jam. The expansion figures are in The Model Engineers Handbook, as are the steam temperatures for given pressure. .
                You also want a really good finish on the portface, because that, or the film of oil on it, is the seal between exhaust and live steam, and you don’t want live steam headed for exhaust, and not bothering with the cylinders in passing.
                Check also that the valve does not lift at all when it is moved by the rod.
                #84128
                MICHAEL WILLIAMS
                  @michaelwilliams41215
                  Hi Michael B ,
                  Could you remind me what engine you are building ?
                  MikeW
                  #84143
                  michael burton 1
                    @michaelburton1
                    hi mikew just building a tich the chassis is getting there jus the valves and nuts to make now oh and the steam tees then should be running on air =)
                    mike
                    #84144
                    MICHAEL WILLIAMS
                      Hello again ,
                      I built a Tich many years ago and thoroughly enjoyed doing so .
                      MikeW
