Gandalf is broken
Gandalf is broken
Home › Forums › General Questions › Gandalf is broken
Viewing 15 posts - 1 through 15 (of 15 total)
  • #434355
    duncan webster 1
      @duncanwebster1
      We have a small statue of Gandalf as a garden ornament, stands about 18" tall made from some kind of plastic. It is hollow, varies between about 1/16 and 3/16 thick. SWMBO managed to knock it off the table and smash it to bits (thank the Lord it wasn't me). I've araldited it back together and filled the bits which couldn't be rescued with car body filler, but it is still riddled with cracks. Next step is to fill it with some kind of gloop which will set and re-inforce the structure. I reckon I need a pint or so, must not shrink on setting or it will be loose, neither expand or it will burst him asunder. Anyone got any suggestions.
      #26916
      duncan webster 1
        @duncanwebster1
        #434361
        Oldiron
          @oldiron
          How about using plaster of paris ? I have used it on ceramic statues and works well. Not sure how good on plastic.. Maybe use an etch primer first to help it adhere.
          #434363
          Ian Skeldon 2
            @ianskeldon2
            Epoxy resin with fine fibreglass matting chopped into very small pieces?
            #434376
              You have my sympathy if your wife can prevail where a balrog failed…
              Aliphatic glue works well on similarly constructed meerkats (long story…) but it's too late now.
              Expanding polyurethane will work as long as you keep it vented, as it's very liquid when first introduced.
              old mart
                @oldmart
                Get one like this, she won't be able to knock it over.laugh
                Brian Oldford
                  @brianoldford70365
                  G26 two part resin.
                  #434385
                  pgk pgk
                    @pgkpgk17461
                    It's often a question of what's to hand. Waterproof PVA swilled inside then stuff gently with newspaper or old rag bits soaked in the same.
                    pgk
                    #434386
                    DMB
                      @dmb
                      Chuck it away n get a noo onedevil
                      #434389
                      Graham Stoppani
                        @grahamstoppani46499
                        Builders expanding Foam Filler such as this?
                        No Nonsense Expanding Foam Filler
                        #434391
                        Jeff Dayman
                          @jeffdayman43397
                          Once it's back together and smoothed up, make a sand mould and cast a second one in aluminum! No more delicate resin.
                          Only half kidding, you could do a wood form box and make a plaster mould or a wax mould (one time use) and cast a new G in concrete or urethane casting resin. A "core" of capped plumbing pipe held in the mould could be used to reduce material amount needed.
                          #434394
                          David Standing 1
                            @davidstanding1
                            Builders fizzy foam is definitely the answer!
                            #434396
                            Bazyle
                              @bazyle
                              The foam might well burst it apart. Don't try to fill it 100%. Do like clay statues and chocolate bunnies. Pour a limited amount of resin or some such in, swill it around and pour the rest out (into some other mould). Allow to dry and maybe repeat but only to build up a thinnish layer inside, not a completer fill.
                              #434399
                              Speedy Builder5
                                @speedybuilder5
                                I have a similar problem, my "Little girl" made of cast cement around about 1900 lost an arm, a leg, head dropped off and fingers on the good arm have frost bite. I have re-modeled with modeling clay, and am about to purchase molding rubber etc, then cast in bronze epoxy. "She" sounds about the same size as Gandalph. She was my grandmothers pond 'nymph', then lived with my aunt at her pond, then with my mother at her pond – and guess what, this winter's project is to make a pond !!
                                #434433
                                  Baby Jesus in our nativity set has his left foot replaced with an epoxy putty prosthetic. Similar surgery restored one of the angels to flight-ready status.
