Current Thoughts on 3 Phase Smart Meters
Home › Forums › The Tea Room › Current Thoughts on 3 Phase Smart Meters
  • #868104
    Colin Heseltine
      @colinheseltine48622
      I am looking at whether to move to a 3phase smart meter to be able to use tariffs such as Octopus Agile rather than variable Rate tariffs.  What are peoples experience.
      Thanks,
      Colin
      #868228
      John Haine
        @johnhaine32865
        Won’t you need a 3 phase supply too?
        #868233
        Les Riley
          @lesriley75593
          I have had a 3ph smart meter for about 3 years now. Works just the same as before except they don’t come and read it!
          I only use 3ph for the workshop, no car charging or night tariffs etc.
          If you have/want solar input you will need a smart meter too.
          #868259
          not done it yet
            @notdoneityet
            Most domestic properties can draw 60 or more Amps on single phase UK supply.
            7kW single phase EV EVSEs are the maximum that can be fitted to a single phase supply, I think.  Three phase EVSEs are available up to 21kW but many cars are limited to 9 or 11kW by the on-board chargers.
            Extra standing charges, for three phase meters, may make their use uneconomical for a domestic installations.  Most Octopus Agile users are on a single phase supply.
            #868302
            howardb
              @howardb
              We have two supplies, I x 230 volt monophase for the house and a triphase 400 volt supply to the barn/workshop.
              Not that have any use for triphase atm, it was going to be mega-euros to remove triphase from the barn and fit a 230 volt supply when we moved in.
              Both have “smart” meters called Linky no problems at all.
              I just tap off neutral and any phase to get 230 volts.
              They transmit to a local hub down the power lines, and then use a central phone system to report the results to Big EDF.
