Fusible Plugs
Fusible Plugs
Home Forums Beginners questions Fusible Plugs
Viewing 21 posts - 1 through 21 (of 21 total)
  • #218233
    Deltic007
      @deltic007
      Got to make one of these for my next project,is normal soft solder Ok or am i better with white metal or lead?
      #7936
      Deltic007
        @deltic007
        #218235
          Use lead
          #218236
          Deltic007
            @deltic007
            Any reason Jason
            #218248
            Martin Connelly
              @martinconnelly55370
              Lead has a higher melting point than eutectic solder (60 40 mix) so may be a consideration.
              Martin
              #218293
              mark costello 1
                @markcostello1
                If there is a specific temperature You need to protect against the alloy might have to be chosen a little more carefully. If the results are generic then the material could also be generic.
                #218315
                  Actually will depend a bit on the working pressure of the boiler, tin can be used and is prefered in the Australian code for boilers under 150psi with lead for ones above that. There is a possibility of the tin crystalizing so should be replaced anually. Pure lead is also easier to get hold of than tin. As in all cases boiler related talk with whoever will be testing the boiler.
                  #218337
                  the artfull-codger
                    @theartfull-codger
                    I allways remove my fusible plug each yr & it there's any sign of movement I re-metal it with either high melting point soft solder or melted sheet lead [4" foster steel boiler.]
                    #218338
                    Bob Youldon
                      @bobyouldon45599
                      Hello,
                      As someone has mentioned it is essential to use a material suitable for use at your desired working pressure plus a suitable additional additional excess. I would discuss the design and materials with your boiler inspector prior to making the thing. Should it be for a pressure vessel in the UK I'd suggest a look at the green book on the subject of fusible plugs. Ideally plugs should be removed for examination each year, primarily to ensure the waterside hasn't become encrusted with scale as this will act as an insulator and the fill material hasn't started to sink through the plug. I understand following the dropping of a plug the boiler should be subjected to hydraulic test.
                      All in all, I consider them a damm nuisance in model use but that's only my opinion.
                      Bob
                      #218364
                      stan pearson 1
                        @stanpearson1
                        I played safe and bought one from Steam Fittings as there is so much to consider when making one
                        Stan
                        #218417
                        nigel jones 5
                          @nigeljones5
                          Question – has anyone actually seen first hand a plug be used for its intended purpose i.e. melting to save boiler/explosion risk?
                          #218500
                          the artfull-codger
                            @theartfull-codger
                            Everyone who owns an engine should have seen one, I re-leaded one for a friend who had a full size aveling roller, as said previously I remove mine every yr & if there's a sign of a slight melt then I re-do it & I allways carry a spare to any rallys,[never needed it btw!!] made both mine out of a bronze chisel as used in the oilworks up here & I check the threads in the boss oif the boiler as well.
                            #218523
                              Posted by fizzy on 30/12/2015 10:46:14:
                              The consequences of a dry top to the firebox are disastrous in full size.
                              I have heard of the plug going on a low boiler but never seen it happen.
                              the artfull-codger
                                @theartfull-codger
                                Fizzy,I misread your post I thought you meant has anyone seen a fusible plug!!, I've seen a couple go at rallys,when going down a steep hill is the worsed, as all the waters down the front end so it must be well full, uphills ok as it's all over the crown, don't know about damage I suppose it all depends how quick you can drop the fire & how long it's been exposed, one of the ones I saw just replaced the plug with a replacement perhaps one of the boiler inspectors on here might care to comment, adverts long ago for drivers used to say"plug droppers need nor apply"
                                #218534
                                Mark P.
                                  @markp
                                  When I worked for a model engineering company we would generally replace the fusable plug on railway locos with a solid bronze plug.
                                  Mark P.
                                  #218540
                                  Deltic007
                                    @deltic007
                                    Why would you do that Mark?
                                    #218543
                                    Mark P.
                                      @markp
                                      According to the boss”if one happens to fail you have to remove the boiler to replace it” those were his words! Personally I would fit one.
                                      Mark P.
                                      #218544
                                      Deltic007
                                        @deltic007
                                        The reason i originally posted was because i am building a New Zealand designed loco and it has one fitted.I will have to consult our boiler inspector to see if it is OK to omit it.
                                        #218545
                                        Mark P.
                                          @markp
                                          I suppose that if you can access it easily through the firebox and grate, if you have a removable grate I would fit one. But see what the boiler inspector says.
                                          Mark P.
                                          #218549
                                          Deltic007
                                            @deltic007
                                            What material would you recommend? Drawing actually says soft solder.
                                            #218552
                                            Mark P.
                                              @markp
                                              As Jason says use lead,or speak to the boiler inspector.
                                              Mark P.
