Favourite old tools…….
Home › Forums › Workshop Tools and Tooling › Favourite old tools…….
Viewing 25 posts - 26 through 50 (of 74 total)
  • #149292
    Nicholas Farr
      @nicholasfarr14254
      Hi Rik, yes you are correct, and as Danny M says it's an opisometer but this one you compare it against the scale given on the map you are measuring although the notches along the frame represent approximatly 5".
      Chris H, not everyone can understand having a shortened shaft on a hammer and they won't use it, but when using them in a tight space, it very often stops you hurting yourself in a tender spot. I also agree the the modern Barco adjustables are not so nice as the old style.
      Regards Nick.
      #149348
      Ian S C
        @iansc
        Ooh well, I went to the second hand shop, and bought the Leytool Micro Divider Setter, It will set dividers up to 6" to .001". I also bought a set of vernier calipers made by Zeus, they are calibrated in thous, and 1/128". On the back is a convertion table, fractions to decimal. Listed price $NZ24 each, got them for $NZ15 each, whether the Leytool device is any use or not, I'll just have to wait and see. Ian S C
        #149358
        thomas oliver 2
          @thomasoliver2
          The disc on the opisometer is on a very fine thread – the finer the better. I made umpteen of these many years ago. The wheel is run along a route to the end and then is run back in reverse along the scale of the map until it locks at zero. This gives an accurate measure of the most convoluted route. We used them in our office to check travel expenses claims.
          #149367
            My brother used to have one that resembled a pen, it had a rubber band inside with a red mark that ran along a scale behind a window. I think you could change the scale (which was on a sheet of paper) by turning a knob.
            I got a digital one many years later – it didn't work!
              @mike89748
              My favourite tool was my dad's Stanley hand drill. I could be wrong, but I think it was acquired from the US Air Force during WW2 when he helped fit British radios to American B17s. It had a gearbox, and on one setting the chuck only rotated clockwise, no matter which way the hand wheel was turned. Just the job for drilling holes in tight corners. Does anyone remember this tool?
              #149387
              Peter G. Shaw
                @peterg-shaw75338
                Nicholas,
                It's a long time since I saw, and used, your little screwdriver, possibly 35 years or so. The secret is, if it's what I think it is, is that it opens up, I forget where, possibly the top, and holds another three blades of varying, smaller, sizes inside.
                Used when I was a GPO/BT technician. Screwdriver, Watchmakers perhaps?
                Peter G. Shaw
                Edited By Peter G. Shaw on 09/04/2014 19:57:10
                #149400
                  Peter,
                  Am I right in thinking that the real beauty of these is that the smaller screwdriver can be "stacked" onto the blade of the larger one?
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Peter, yes you are correct, however in this one there are only two and always have been only two. As you say the top unscrews and the smallest one fits inside the middle one, which fits inside the main one.
                    Michael, you are right in thinking that the smaller ones can be stacked onto the blade of the larger ones.
                    When the smallest one is in use the total length is 140mm, the main screwdriver length is 95mm long.
                    Regards Nick.
                    #149404
                      Thanks Nick
                      NJH
                        @njh
                        Nick
                        Peter refers to a " Screwdriver, Watchmakers" ( a good old GPO / PO / BT tool and designation!) which is not quite the same as your example. The PO version had, like yours, a brass body but the end cap – against which pressure was applied by the index finger – was free to rotate whilst the body was turned under the control of the thumb and middle fingers. The cap could be pulled out and revealed space in the hollow body which contained other blades. There were, if I recall correctly, three blades of varying sizes. The blade selected fitted into a "collet" at the business end. ( Telephone exchanges, in the electro-mechanical age, contained many, many intricate mechanisms in constant need of adjustment  – I've made a few adjustments in my time!)
                        Norman
                        Edited By NJH on 09/04/2014 23:36:04
                        #149498
                        Peter G. Shaw
                          @peterg-shaw75338
                          Nick & Norman,
                          Norman is correct, Nick's screwdriver, although basically similar to the GPO one, is definitely not the GPO one. The GPO one definitely did have 3 blades inside, although until Norman reminded me, I could not remember either how to get in to them, or how they fastened on the outside.
                          Interesting though how two very similar tools they are, yet with different ways of achieving the same objective.
                          By the way, Screwdriver, Watchmaker's was a guess at what it was called.
                          Peter G. Shaw
                          #149694
                          Oompa Lumpa
                            @oompalumpa34302
                            Well here is another one of mine, I actually have two of these and find them very handy on the Micro Lathe, it is marked 5 and 10 but units of what I wouldn't like to guess :
                            #149695
                              Graham,
                              There was one on ebay last December
                              … listing mentions the Patent number.
                              Edit: That was the application Specification number
                              … here is the Patent.
                              Edited By Michael Gilligan on 12/04/2014 22:26:23
                              Edited By Michael Gilligan on 12/04/2014 22:30:54
                              #149696
                              Oompa Lumpa
                                @oompalumpa34302
                                Posted by Michael Gilligan on 12/04/2014 22:13:30:
                                Graham,
                                Patent number is on the back Michael. I didn't take a pic of the back but it mounts quite simply, on the back there is a small piece of plate retained by the two thumbscrews you see on the front, very convenient and attaches to almost anything, round, square, oval and so on.I have had one forever and the second, more recent acquisition was in a job lot of tools I bought.
                                graham.
                                #149698
                                  Posted by Bogstandard2 on 12/04/2014 22:46:31:
                                  … and I still have loads left
                                  A little evidently goes a long way
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Posted by Oompa Lumpa on 12/04/2014 22:25:27:
                                    Graham,
                                    graham.
                                    Hi, I also have one of these which was my farthers, but it dosen't have a patent number on it, **LINK** and the other side **LINK** I believe the units are 0.001"
                                    Regards Nick.
                                    #149706
                                    “Bill Hancox”
                                      @billhancox
                                      I am pleased to see that other members have a device that was a puzzlement to me until now. I too have a sample of "The Unique" indicator that came in a box of tools with my Speed 10. I often wondered if it had a special application. I once miked it and found it to be calibrated in one thou increments and quite accurate. Thanks for the post. Blessings upon you and may the moths never infest your woolens.
                                      Bill
                                      #149763
                                      Robert Dodds
                                        @robertdodds43397
                                        Continuing the idicator theme I recall seeing an alternative, may be even a de-luxe, version in the bottom of my toolbox. The pic shows a Verdict Junior, which research suggests was patented in 1943 so its a bit later than the Unique (1928)img_20140413_182156.jpg
                                        The mounting arrangement is a bit more sophisticated, clamping securely on a 1/4" bar and also incorporates a split nut that allows the indicator body to be swivelled round to any angle and as with later Verdict indicators the stylus has a stiff slip joint to alter the strike angle
                                        regards
                                        Bob D
                                        Edited By Robert Dodds on 13/04/2014 20:28:26
                                        #149802
                                        roy entwistle
                                          @royentwistle24699
                                          I have got two of these verdict ones one with stylus sprung to the right the other sprung to the left they are both very useful
                                          Roy
                                          #149807
                                          maurice bennie
                                            @mauricebennie99556
                                            Hi please can someone explain to me what on earth they are for as in all my very long life I have never seen one .
                                            Because if they are so useful I want one ! Thanks Maurice
                                            #149815
                                            Peter G. Shaw
                                              @peterg-shaw75338
                                              Whilst the modern DTI's may well be more accurate and easier to read, these little Verdict indicators are physically small and in some instances this can be very useful indeed.
                                              I have one of these along with a plunger type DTI and a lever type DTI. All have their uses.
                                              Peter G. Shaw
                                              #149816
                                                Posted by maurice bennie on 14/04/2014 11:15:16:
                                                Hi please can someone explain to me what on earth they are for …
                                                Maurice,
                                                This is a very good place to find the explanation:
                                                #149819
                                                Ian S C
                                                  @iansc
                                                  Ideal for setting up work in the four jaw chuck on the lathe. Ian S C
                                                  #152521
                                                  Raymond Sanderson 2
                                                    @raymondsanderson2
                                                    Favourite old tool thats a difficult one as I have some of my Dad's old woodworking gear
                                                    Our old next door neighbour an ex-navel engineer gave me some of his old tools scribes, callipers, drills, centre finder
                                                    Others I have like the Engineers clamp made at school and scribe post then others I procured in my own working life as well as after.
                                                    I attend here in Sydney The Traditional Tools Group sale each year a good source of old tools. As well as at field days. I am not a collector as such if the tool can't be of use its doesn't follow me home.
                                                    I know I was in anxiety mode for months trying to locate a missing double wire/sheet metal gauge I had had since my first year as an apprentice. It was found in a draw almost placed so i would find it.
                                                    #152711
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      Haven't used it for years, now, but did regularly, my late father's pre WW 2 7/16 hexagon drive Britool socket set.
                                                      Borrowed and used this set to earn my first money for repairing cars. Have only ever replaced one socket, (which was already cracking, before I took ownership). It must have been one of the last Britool 7/16 hexagon drive sockets around in the late 1960s. Everything else is flame marked instead of chrome finish.
                                                      Have worn out more modern sockets, so that says a lot about the quality.
