Hi Peter ,
When doing any lathe work it is only what the tip of the cutting tool is doing which matters . Prvided the tool is securely fixed and with minimum overhang the way the tool shank is arranged is just a matter of clearance , convenience and safety .
A very good tool to use for facing is one with a radiused cutting tip . Apart from usually cutting freely and producing a nice finish this type of tool is very tolerant as regards the exact angle of cutting to which it is set . Basicaly the round tip looks the same to the work several degrees either way of the ideal setting angle .
A tool which is useful for facing and a variety of other purposes is a V tool with cutting tip rounded end as described above .
A sometimes significant problem with facing large diameter work is that the cutting speed is high at the outside but drops rapidly as you approach centre . Wth , for instance , an uncooperative casting it is sometimes better to turn away a lot of material at the outer diameters at a low spindle speed then change to a higher spindle speed for final facing of the whole surface .
MW
Edited By MICHAEL WILLIAMS on 23/01/2012 09:47:08
