ER25 collet arbour grub screw
Home › Forums › Beginners questions › ER25 collet arbour grub screw
  • #413963
    AdrianR
      @adrianr18614
      I have a Vertex ER25 collet arbour. When I removed a cutter today a M10 x12 hex key grub screw fell out. The MT is taped all the way through and it seems the grub screw was in the collet end. It does not seem to tighten against anything the thread just seems to get crunchy and I have not forced it further in.
      The grub screw is not pointed, it is the type with a centre hole.
      Any idea what the grub screw is for and which way round it should be in?
      Thanks
      Adrian.
      #9714
      AdrianR
        @adrianr18614
        #413969
        John Haine
          @johnhaine32865
          It may be to make sure the cutter goes in at a repeatable projection from the collet. I have some ER16 collet chucks with something similar.
          #413973
          AdrianR
            @adrianr18614
            The screw is very short for that, also it is not tight so would move.
            #413975
            John Reese
              @johnreese12848
              Posted by John Haine on 12/06/2019 20:42:27:
              Yes! It also prevents the tool backing up during a heavy cut.
              #414011
                Or if the thread goes all the way through and is just become clogged with muck it may once have been used to eject the taper if the tooling was ever used in a tailstock. I put a grub screw in mine when using it that way.
