Posted by Tim Ellis on 19/05/2019 18:14:45:
Hi Dave,
Many thanks for the reply, I'll look into this tonight. Can I ask how you calculated the right fuse? Its just I'll probably build a second in time and would like to understand every little aspect.
Many thanks, Tim
Hi Tim,
It's from the equation Watts = Volts x Amps
Thus:
Amps = Watts divided by Volts
The specification of the TE952 says it can dissipate 250W and you have a 12V, battery so
Amps = 250 /12, rounded down to the nearest standard size = 20A.
I suggested 30A if you're brave because the TE952 can certainly withstand short bursts of higher current, so rounding up to 30A isn't foolhardy. An accidentally shorted battery could deliver several hundred amps – enough to melt the wires – so you want to size the fuse to deal with normal operation, about 20 to 30A, and to pop quickly if more than that is drawn due to a fault.
sadcastings website doesn't give any clues about the motor ratings, bit anti-social possibly it's tucked away on the plans! But judging from the price and photos, 10 amps each looks reasonable, and 20A total would be compatible with the controller.
