Is there a rule of thumb for the amount of interference by metal types and diameters for a press fit? I haven't managed to find one online.
For the cast iron bushings going into my throughhole in ally I turned them just over 2thou oversize for the 29.40 and 29.45mm holes in the ally block. I then made a spindle to their 24mm ID to keep them aligned for pressing.
Not having a press I planned on using the bench vice but since the 90mm block plus bushings was a tad long to fit I had little choice but whale on the end with a wooden mallet to get them seated such they'd go into the vice. They did press in but only with a pipe extension over the vice handle (which bent in the process). I'd expected to press into a soft alloy easily – for sure they're not going anywhere..
