Posted by Robin Graham on 14/04/2022 01:01:26:
Posted by Michael Gilligan on 13/04/2022 19:33:38:
Thanks to Dave and Thor … I am reminded of a previous thread on this forum, about micro-bubbles generated in canine toothpaste.
I am happy to believe that the underlying process is generally similar.
Ref. **LINK**
Edited By Michael Gilligan on 13/04/2022 19:36:14
On the chemistry front I'm pretty skeptical about claims that vinegar 'attacks' grease in a chemical way. It's certainly true that grease can be broken down by dilute acid (acid hydrolysis of esters), but I doubt that the reaction is significant in cleaning an oven. Possibly it has some mild solvent action?
That's what I was hinting at when I said the answer was as much to do with physics as chemistry. Dilute Acetic Acid isn't like Caustic Soda, which attacks fats aggressively; Vinegar only has a mild dissolving effect. Simply splashing vinegar on a dirty oven won't get it clean. It's important that the Bicarbonate / Acid mix be a paste, in which the Bicarbonate and Acid are slowly reacting to produce micro-bubbles, AND there are plenty of sharp Bicarbonate crystals to act as an Abrasive, AND there's enough fluid to penetrate tiny cracks and crevices, AND the paste is rubbed in enthusiastically by the operator. Works in much the same way as soapy Brillo-pad, except the Brillo pad abrades with steel-wool, soap breaks up the fat and there are no micro-bubbles.
Cleaning an oven with a solution of Sodium Acetate made by carefully neutralising Sodium Bicarbonate with Vinegar is a waste of time. It's not reactive or abrasive and there are no micro-bubbles.
Caustic Soda paste, made with water, can be splashed on and left. The alkali breaks fats up, so the operator can leave the oven to soak and wash the whole lot off with water a few hours later. Sodium Bicarbonate would do the same but take a lot longer.
Anyone tried Isopropyl alcohol? Apart from the cost, fumes, and fire hazard I think it might work well. Ditto petrol…
