Dividing Plates
Dividing Plates
Home Forums Beginners questions Dividing Plates
Viewing 25 posts - 1 through 25 (of 32 total)
  • #329272
    martin107
      @martin107
      Hi I have bought a HV6 Rotary Table with Dividing Plates​, is there an Idiots guide on how to use the Dividing Plates, what I have seen up to now a degree in maths would be handy.
      Cheers
      Martin
      #8980
      martin107
        @martin107
        #329274
        Stuart Bridger
          @stuartbridger82290
          If you Google "dividing head manual" and find the Grizzly manual. That has a good worked example.
          #329275
            This is probably the best introduction I have seen, Martin **LINK**
            http://www.arceurotrade.co.uk/projects/rotarytable/UsingARotaryTable.pdf
            But do be aware that the example he is using is 1:72 ratio
            … Yours is most probably 1:90
            Alan Waddington 2
              @alanwaddington2
              There are quite a few online calculators that take out the maths and any head scratching. Just punch in the numbers.
              Robbo
                @robbo
                The Vertex HV6 rotary table is certainly a 1:90 ratio worm/wheel
                Edited By Robbo on 26/11/2017 19:23:46
                #329282
                martin107
                  @martin107
                  You are quite correct it is a 1:90 one from Warco and thanks for all your advice you have managed to fry my brain nicely on a Sunday evening, I think I will have to fit it and have a play just to give me some Idea what's what because I'm afraid at present it all seem's double dutch but hopefully when I have had a play it will make some sort of sense Cheers
                  #329285
                  Stuart Bridger
                    @stuartbridger82290
                    As an apprentice piece we had an exercise called a polygonal pyramid to get us used to working with a dividing head. A 3 inch turned blank of aluminium with steps of decreasing diameters. Onto this we had to mill polygons from 3 to about 10 sides. Mine went well apart from one was a few degrees out from backlash. That was over 35 years ago and I haven't used a dividing plate since… I would recommend this sort of exercise to practice before cutting anything important.
                    #329286
                      Martin,
                      If you can follow the explanation for the 1:72 model
                      AND then convert for 1:90
                      Then; as my lecturer daughter likes to say "learning will be seen to have taken place".
                      Sit down quietly with a glass of malt …
                      Yngvar F
                        @yngvarf
                        Grizzly has a pdf. Instruction that is quite good.
                        Included is the numbers for most divisions. No math requred.
                        When it says e.g. 3 12/30 that means 3 whole turns and 12 holes on a 30 hole plate.
                        Then the fingers need to be 13 holes apart.
                        #329293
                        mark smith 20
                          @marksmith20
                          I found this video quite informative and easy to follow , for simple indexing , when i started using mine .
                          You have to make sure you know your worm ratio as mentioned above.
                          Tim Stevens
                            @timstevens64731
                            With a 90:1 dividing head, each full turn of the handle moves the work round by 360 / 90 = 4 degrees. For one degree, turn the handle a quarter turn exactly.
                            For angles that are not neat multiples of 4 degrees, a dividing plate allows you to turn the handle by a set smaller amount, and so to turn the work by a set even smaller amount. A ring of 10 holes allows the handle to be turned 1/10 of a turn, so as one turn = 4 degrees, 1/10 of a turn moves it 4/10 degree = 0.4 degrees. So, a ring of 40 holes gives you 1/10 degree = 0.1 degree.
                            And so on. It can get complicated if you want an angle of seven degrees and thirteen minutes and nine seconds – but it is just a matter of choosing a plate with the 'nearest correct' number of teeth. Unless you have a large number of plate circles of different numbers, an approximation is the best you can do, usually.
                            Cheers, Tim
                            #329299
                            martin107
                              @martin107
                              I think I'm starting to get the grasp of it, but with me I find actually doing it gives me a lot better understanding of it.
                              As to the malt ahh the good old days, strictly soft drinks now, but thanks for the advice.
                              Thanks
                              Martin
                              #329303
                                Posted by martin107 on 26/11/2017 20:24:52:
                                I think that's essential. You have to suss out the table in the manual, select the right plate, and the right ring of holes, set up the hands, and then keep count as the handle is turned relative to them. Takes a bit of getting used to!
                                I 'got it' by first experimenting with very simple angles. I was able to confirm I was doing it right by checking the HV6 was turning correctly against its degree scale.
                                Once the table in the manual is understood it's not too difficult to use in principle. In practice I make mistakes. You have to take care not to lose count whilst cranking the handle. That's why quite a few of us have added stepper motors to our rotary tables and use a small computer to do the sums. Ask again if you're interested in that; there's been much discussion on the forum about an MEW article describing how to make one.
                                Weary
                                  @weary
                                  Cheap and simple way of keeping count of handle turns in short youtube video here.
                                  Phil.
                                  #329382
                                  Brian Wood
                                    @brianwood45127
                                    You can also use bits of cocktail stick in spare holes to block unintended movement of the sector arms if you catch them with the peg in the turning handle whilst winding. That too will prevent a ruined job.
                                    Regards Brian
                                    #329404
                                    Brian H
                                      @brianh50089
                                      Just be aware that a couple of errors have been reported with the table in the Vertex handbook. I forget the details but someone posted on here several months ago (or it might have been years knowing my memory!)
                                      #329454
                                      Dave Halford
                                        @davehalford22513
                                        Use the dividing plates, it's very easy.
                                        Just did my first gear – 16dp 90 tooth. Use the online calculator, set the depth of cut to just enough to mark the blank and pretend to cut the gear. When you end up back at the start on the same mark, do it again with the proper depth of cut. Just make sure the finger relationship doesn't move.
                                        I was surprised how easy it was.
                                        just takes a while smiley
                                        #329457
                                        John Haine
                                          @johnhaine32865
                                          …or of course you can add an electronic indexer and forget all these problems…wink 2
                                          #329466
                                          Robbo
                                            @robbo
                                            Posted by Brian Hutchings on 27/11/2017 15:08:03:
                                            Howard Lewis pointed out the errors on this thread **LINK**
                                            Neil has posted the revised tables somewhere smiley     click on "Workshop" to find it
                                            Edited By Robbo on 27/11/2017 23:11:50
                                            #329514
                                            larry Phelan
                                              @larryphelan54019
                                              There a many errors in the books supplied with these tables,no matter what the make. Dont believe all you read !
                                              #329518
                                                Posted by larry Phelan on 28/11/2017 10:02:01:
                                                Which is exactly why I suggested 'learning' …
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    Hello Neil,
                                                    I seem to remember that someone spotted an error in the table you refer to. I cannot work out if that error has been corrected or not. Can you confirm it is now as error free as possible?
                                                    #329589
                                                    Brian Wood
                                                      @brianwood45127
                                                      Andrew,
                                                      You can do some checking yourself to be sure what you read makes sense.
                                                      As an example with a 40:1 dividing head (Brown and Sharpe design) the maths is 40 divided by the number of divisions you are wanting to put into the component. You can then compare that with the table results to see if the maths is correct and if not, the table value will be wrong.
                                                      Regards Brian
