Dividing Plates
Dividing Plates
Home › Forums › Beginners questions › Dividing Plates
Viewing 7 posts - 26 through 32 (of 32 total)
  • #329647
      Posted by Andrew Tinsley on 28/11/2017 15:00:12:
      Hello Neil,
      I seem to remember that someone spotted an error in the table you refer to. I cannot work out if that error has been corrected or not. Can you confirm it is now as error free as possible?
      My recollection is that Howard corrected it, but I suggest sense-checking your results. You can also download his spreadsheet to see how they are derived.
      #329659
      Andrew Tinsley
        @andrewtinsley63637
        Thanks Neil,
        I will get the brain in gear and download the spreadsheet and check the suspect entry.
        Andrew.
        #329660
        Andrew Tinsley
          @andrewtinsley63637
          Thanks Neil,
          Andrew.
          #329818
          Howard Lewis
            @howardlewis46836
            A little acccessory that has proved useful is home made pin to sit in in a hole behind one of the sector arms, once they have been clamped together. It lessens the chances of moving the sector arms accidentally.
            F W I W, try to get into a sequence of actions, such as: unlocking the table, indexing, resetting the sector arms, turning the handle, locking the table, cutting.
            If you have a memory, and powers of concentration like mine, you will need to! (not to mention lack of typing skills)
            Edited By Howard Lewis on 29/11/2017 22:00:33
            #329831
              My technique has been to use a 60-division dial with a 60-turn worm, so only 6-arc minute resolution.
              I do a spread sheet that lets me know how many full turns and then what dial reading to carry on to. It requires much care and yes I do get too many cock-ups.
              A stepper powered table is on the horizon. I bought and HV6 but I think it's too big to convert as it will be totally HUGE! But surprisingly nice so I will keep it, especially as I have a 10" gear coming up!
              So will probably get a small 4" table for conversion.
              #329856
              Brian Wood
                @brianwood45127
                Howard,
                My home made pin started off as a golf tee, suitably slimmed down. I now use cocktail sticks, fiddly pins are easily lost and I just break off a length that suits clearance with the winding handle. The method has prevented a potential failure from lost position more than once; catching the sector arms with the handle and pin is all too easy
                #329862
                Howard Lewis
                  @howardlewis46836
                  Thank You Brian!
                  What a good idea. Must chat with some of my friends who play golf.
                  Much less likely to get lost than a bit if steel rod.
