digital height gauge displays random numbers
Home › Forums › General Questions › digital height gauge displays random numbers
  • #111524
    Dismaldunc
      @dismaldunc
      Hi Chaps
      I bought a digital height gauge from Allendale at the last Harrowgate show, It has been a joy to use and improved my accuracy no end. However this am when I went out to play (with an ambitious set of ideas in my head for a good 4 hour session) it just gives a bizzarre ever scrolling read out. I shall of course contact Allendale tomorrow but wondered if there is anything I can do to make it play nice ( I have changed the battery ) for the rest of the day.
      Dunc
      #22464
      Dismaldunc
        @dismaldunc
        #111525
        Engine Builder
          @enginebuilder
          I have had this with mine. A new battery put it right. I would try another in case the one you fitted was a dud.
          #111527
            You could bring it into the warm house and see if that improves things after a few hours. Was it a new battery you fitted or one you have had in the cold workshop for some time?
            J
            #111530
            Alan Reed 1
              @alanreed1
              I had a similar problem . Turned out to be radiation from a low energy lamp ( ie mini fluorescent ) that I was using in my work light.
              #111532
              Dismaldunc
                @dismaldunc
                Hi chaps
                Thanks for the rapid replies, I have tried 2 new batterys but both were stored in a cold work shop, So I have brought the poor thing into the warm for a little TLC.
                I will see if that helps
                Dunc
                #111539
                Paul Lousick
                  @paullousick59116
                  I have found that thse types of gauges do not like moisture. The DRO's on my mill sometimes have similar symptoms when it has been raining for a long period. They operated correctly after they have dried out.
                  #111541
                  NJH
                    @njh
                    Hi Dunc
                    I too suspect the effect of cold on the batteries – I don't operate too well when I'm cold!
                    Another point to watch is the source of your batteries – going for the "bargain" ebay offers is usually not the best way forward.
                    N
                    #111544
                    colin hawes
                      @colinhawes85982
                      I've had similar problems which,on very close examination, turned out to be caused by almost invisible (to my old eyes) corrosion .A little scrapeand a smear of oil on the battery worked fine on my 150mm vernier. Colin
                      #111547
                      Dismaldunc
                        @dismaldunc
                        well that seems to be sorted.. Brought it into the house for a warm and it now seems like a happy bunny. Righty then Tinas main bearings it is then!
                        Thanks Lads
                        Dunc
