DC Motors Vs AC induction (single or three phase)
Home › Forums › General Questions › DC Motors Vs AC induction (single or three phase)
Viewing 25 posts - 1 through 25 (of 61 total)
  • #223734
    MW
      @mw27036
      Y'know i'm always up for a bit of chit chat but, can anyone tell me what is it exactly that makes AC induction motors more powerful than their DC counterparts?
      Michael W
      #24360
      MW
        @mw27036
        #223740
        roy entwistle
          @royentwistle24699
          I would have thought that a 1 horse ac induction motor was the same as a 1 horse dc motor But its a long time since I was at tech
          Roy
          #223741
          MW
            @mw27036
            Yeah, maybe dc motors have had a bad time because theyre normally used for variable speed and AC ones are normally belt driven, there still seems to be a distinctive lack of grunt from a DC motor though, i mean i haven't seen an old english lathe use anything but single/three phase induction AC
            #223742
            MW
              @mw27036
              I heard rumor that in the days before Induction motors all you had were big and beastly DC motors though, perhaps they were rather energy inefficient
              #223744
              Ian Parkin
                @ianparkin39383
                DC motors are far smaller than AC for the same output
                But in general as Roy says a 750w DC is the same as a 750W AC…. 1 horse output
                #223746
                John Reese
                  @johnreese12848
                  DC motors in powr tools run at very high RPMs. That allows a lot of power in a small motor. AC motors running on line current cannot exceed 3000 or 3600 RPM (synchronous speed) depending on whether you have 50 or 60 hz.
                  #223751
                  MW
                    @mw27036
                    "DC motors are far smaller than AC for the same output"
                    Yep, it makes them ideally suited for mounting onto a mill because it can support the weight of it better.
                    I wonder if its more a question on the number of poles per motor that dictates both slower speed but more inertia.
                    #223752
                    MW
                      @mw27036
                      i remember someone once saying that on the face of it, a basic motor rotated by magnetic energy appears to be a very feeble thing and a wonder it ever worked in the first place, but then theyve done an awful lot to make them better and better at what they can produce over history.
                      Edited By Michael Walters on 03/02/2016 11:40:21
                      #223756
                      Martin Kyte
                        @martinkyte99762
                        Back in the day if you wanted variable speed on large machines (10's of HP upwards) you generally went for DC motors with Ward Leonard control. You start off with a 3 phase machine as a prime mover driving a DC generator. The Generator supplied your DC motor on the machine and by controlling the current in the field windings you had variable speed. This could be done simply with a switched resistor bank. Upgrades when semiconductor control arrived usually consisted of upgrading the current control by replacing the resistors with 3 term controllers.
                        I can think of several other high power applications, Trains,Trams and Submarines to name but three.
                        Martin
                        #223758
                        Ajohnw
                          @ajohnw51620
                          if you get to the bottom of this subject neglecting things like permanent magnet motors you'll find that the sizes of an AC and a DC motor will be very similar if they run at the same speed and provide the same output power.
                          Essentially DC and universal motors can run at higher speeds so can be smaller for the same horse power output.
                          roy entwistle
                            @royentwistle24699
                            John Reese Wrote "AC motors running on line current cannot exceed 3000 or 3600 RPM (synchronous speed) depending on whether you have 50 or 60 hz." I would suggest that this only applies to induction motors Brushed ac motors in hand drills etc certainly can exceed this speed
                            Roy
                            #223763
                            Muzzer
                              @muzzer
                              Posted by Ajohnw on 03/02/2016 11:59:13:
                              Indeed true to a fair extent. Bottom line is that the torque generated in the gap between the rotor and stator is limited by the saturation flux of the steel laminations (regardless of how the field is generated) – and the active surface area of the rotor. Beyond that it's a question of how fast you can operate it (power = torque x speed).
                              The main difference between induction and permanent magnet motors of equivalent rating is the size of the rotor. Modern magnets inherently produce a strong field, whereas the rotor in an induction motor only generates torque as a result of the current induced in it by the rotor slipping against the rotating field. There's more material and gubbins in its rotor (which is basically a shorted winding) required to generate the same field. This is why modern electric and hybrid vehicles tend to use PM machines and bigger, lower tech (eg older US) vehicles tended to favour (favor?) induction machines.
                              #223764
                              Muzzer
                                @muzzer
                                Posted by roy entwistle on 03/02/2016 12:46:20:
                                Roy
                                The minimum number of poles you can have is 2, which means at synchronous speed (ie with zero load), it will spin at these speeds. For a 4-pole machine it would be 1500/1800 rpm. The more pole pairs, the slower the synchronous speed. Of course, if you drive them with a VFD, the speed is simply limited by the mechanical and electrical parameters – back emf, burst speed etc.
                                #223766
                                John Haine
                                  @johnhaine32865
                                  It's an odd fact but true that the Tesla, one of the most advanced electric vehicles, uses an induction motor with a VFD,
                                  One of the reasons for this I have heard is that it is not dependent on expensive rare earth elements; and also the motor is immune from demagnetisation over time which I believe can happen with PMs.
                                  And another interesting point is that an induction motor is basically a transformer, and the flux in a transformer core is, ideally, zero.
                                  #223767
                                  Martin Kyte
                                    @martinkyte99762
                                    " the flux in a transformer core is, ideally, zero" ? WHAT
                                    No field = No coupling = No transformer
                                    Martin
                                    #223772
                                    roy entwistle
                                      @royentwistle24699
                                      Muzzer I think you are confusing brushed universal motors with synchronous motors   Think of routers, engraving machines, etc All faster than 3000rpm
                                      Roy
                                      Edited By roy entwistle on 03/02/2016 14:43:14
                                      #223775
                                      Mike Poole
                                        @mikepoole82104
                                        DC was the motor of choice for variable or high speed applications until the arrival of semiconductors we could build a VFD with. With the addition of an encoder it is possible to get a basic squirrel cage motor to perform as a servo drive with full torque at zero rpm. The encoder is needed to give motor speed and rotor position so the current can be supplied at the right time to develop full torque at zero rpm. Encoder less drives cannot hold at zero rpm but low rpm can be achieved with good torque by some clever sensing and maths to estimate rotor position, the VFD drives that can do this usually incorporate the words flux and vector some where in their description. DC motors require specialist care and maintenance but the squirrel cage motor is virtually bulletproof with a minimum of maintenance.
                                        A DC motor is much more complex to make than a squirrel cage motor and requires a fairly complex control, an AC motor and pulleys or gearbox is simple and effective for a machine tool drive, but as many have found, a VFD can make a machine very flexible and a pleasure to use.
                                        #223777
                                        JA
                                          @ja
                                          Don't know but let's have a go at answering the original question.
                                          I assume the power of a motor is based on the supply current and voltage and not measured on a brake. If so the delivered power would depend on the motor and gearing if necessary. Hazarding a guess I would think that an induction motor would be slightly more efficient than a brushed non-permanent magnetic field DC motor: both would have similar field and bearing losses but there would be losses at the commutator. If the motor required a gearbox that would add to the losses. There are other smaller losses like windage.
                                          I have to admit that I last did any motor analysis at tech nearly fifty years ago.
                                          JA
                                          #223778
                                          Ajohnw
                                            @ajohnw51620
                                            Actually I don't think that an AC motor will produce much torque at 1500, 3000 rpm as mentioned for 50Hz. That's why circa 1400 and 2,800 are more usual and 3000 rpm off hand grinders wild claims. There needs to be some slip in practice.
                                            Clive Foster
                                              @clivefoster55965
                                              In practice there is often a considerable difference between perceived and actual power. Actual power really only matters at full load which pretty much never happens in most peoples real world experience. A vacuum cleaner is probably the closest to full time, full power operation that most of us will ever see.
                                              What we perceive as power is really the torque / load / rpm characteristic. When you increase the load on rotating machine the motor needs to generate more torque. For normal devices lacking relatively sophisticated controls the motor has to slow down to generate more torque. A motor which slows down more than you expect for any increase in load is seen as being less powerful, or in the vernacular, gutless. In contrast one that absorbs load increases with very little change in speed is often said to be torquey and will give the impression of being more powerful whatever the dyno may say. I suppose a proper analysis of work done over time might vindicate this impression.
                                              #223792
                                              MW
                                                @mw27036
                                                Combining an AC motor with a VFD and utilizing some aspects of mechanical reduction, like high and low gear settings seems to be a good way of machining all but the toughest of applications.
                                                I use a mill with a DC motor at 750 watts and a lathe with an AC motor at 750 watts, both have some form of power control i.e PWM or a VFD and i can honestly say its hard to tell the difference. But my pillar drill has a single phase motor at 370watts but only uses mechanical reduction and it feels like i could plunge a drill as hard as i like and it'll take it in its stride. So what clive is saying probably is true.
                                                Michael W
                                                #223804
                                                Muzzer
                                                  @muzzer
                                                  Posted by Ajohnw on 03/02/2016 15:02:40:
                                                  Yes and no. You are answering a different question. The "synchronous" speed is what you would see if there were no net load (read my words above), including windage and bearing loss (not quite practically possible). The only way to make them go faster is to give them a negative load ie make them regenerate. The machine works in exactly the same way but now the torque is opposite and the motor generates electrical power.
                                                  The rated power is with some slip, like about 5-10% or so of base frequency. It's usually thermally limited.
                                                  #223805
                                                  Muzzer
                                                    @muzzer
                                                    Posted by roy entwistle on 03/02/2016 14:29:48:
                                                    Roy
                                                    Lost me there. Don't recall mentioning the former. I think I'm reasonably conversant with motor technology, having designed and developed a variety of synchronous and asynchronous motors for electric, hybrid and conventional vehicle applications.
                                                    The reason Tesla uses asynchronous (induction) motor is partly the US tradition of using them and partly their desire to avoid reliance on rare earth magnets, given that the Chinese now seem to own most of the raw materials. It's also a little more tricky to design a really good PM machine.
                                                    #223808
                                                    Ajohnw
                                                      @ajohnw51620
                                                      Posted by Michael Walters on 03/02/2016 16:05:11:
                                                      Michael W
                                                      The reason for the belt drive being more powerful is because that style of speed reduction actually increases torque so apart from losses in the drive power remains the same. Electronic speed control on either type of motor doesn't do that. Torque tends to be constant so actual power is reduced as the speed is slowed down. Some ac inverter drives model the heating effects of the motor so may actually drop the troque. This happens because the motors have a max current rating and running them more slowly doesn't mean that they can pass more current – less in practice because at some point they will overheat as the usual cooling fan is also running at a lower speed. Actually in principle it's better to speed them up but at some point the armature will burst due to centrifugal forces.
                                                      As Ketan of Arceuro mentioned it's hard to be sure about what the actual output power of variable speed machine tools really is. The ones he sells are rated on output power. Some may be rated on input power. Either might have power stated for a certain time limit. Some AC motors state continuous some don't.
                                                      Edited By Ajohnw on 03/02/2016 17:56:07
