Compressors
Compressors
Home › Forums › General Questions › Compressors
  • #458986
    Malcolm Begg
      @malcolmbegg82759
      I have a compressor which runs but the motor pulley gets extremely hot,the motor itself is quiet cool,I have replaced the bearings but the pulley still heats up?
      Any help would be appreciated
      #27219
      Malcolm Begg
        @malcolmbegg82759
        #458988
        Ian Parkin
          @ianparkin39383
          Does the pulley on the pump get hot too?
          #458990
          john barnes 4
            @johnbarnes4
            Could the pulley be slipping on the shaft and causing friction. Check you have a woodruff key in.
            #458992
            Emgee
              @emgee
              Could be belt slip but normally you would hear it screaming so be aware.
              Emgee
              #458993
              Kiwi Bloke
                @kiwibloke62605
                …or the belt slipping. However, its more likely because V-belts heat up simply by deformed by their having to flex around the pulleys. Worse if the pulley is of small diameter and/or the belt speed is high, and, of course, the heat builds up as long as the belt runs, until heat loss mechanisms balance the heat input. For machines which run for a long time, hot belts aren't uncommon.
                #459003
                Nicholas Farr
                  @nicholasfarr14254
                  Hi, Malcom, could be the pulley is worn? Does the bottom of the pulley V look shiny? If it does, then the belt may be rubbing on the bottom, which it should not do, there should always be a gap between the bottom of the belt and the bottom of the pulley V.
                  Regards Nick.
                  #459013
                  Kiwi Bloke
                    @kiwibloke62605
                    Forgot to say that internally-notched belts, being more flexible, run considerably cooler. Modern belts can take 60C running temp OK, but their life will be roughly halved.
                    #459029
                    Trevorh
                      @trevorh
                      Vee Belts if correctly aligned will last years
                      first option is belt dressing spray – prevents / reduces slippage and therefore running temp
                      second option check Tension – google for the correct deflection distance
                      if the above are good and good alignment then the only heat generated is as the belt is creating slight friction as it goes around the pulley's, they are designed for this
                      Easiest way to check for alignment is either a straight edge or piece of string
                      to use the string simply rotate by hand 1 pulley trapping the string under it, rotate to a mid point and now pull the string tight across the other pulley, look at the faces (edges of the pulleys and adjust until the string when pulled across both pulley's touches across both at the same time
                      Trevor
                      #459033
                      not done it yet
                        @notdoneityet
                        ‘Extremely hot’ is clearly subjective. In my parlance, extremely hot would be damaging (or has damaged) the belt, for certain.
                        I carry dinner plates to the table with my bare hands, while my wife would be using insulated mits, for instance. Same temperature, different tolerance.
                        An actual temperature would be useful, as exaggeration often accompanies threads like this. Make and size of the compressor would help, too. Cheaper-end compressors run at high speed and/or use minimum-sized motor pulleys that are more susceptible to problems like this.
                        I would suspect that the belt has seen its day and needs replacing.
                        #459048
                        Howard Lewis
                          @howardlewis46836
                          As NDIY says, "HOT" is relative. If you can bear your hand on the pulley, it is probably below 80'C
                          The pulley will be warmer than its surroundings because of the friction between belt and pulley as it enters and leaves the groove..
                          My first suspect would be belt slip. This assumes that the problem has only just arisen, and that the belt is the correct section, so that it is not down in the bottom of the V groove. The back of the belt should be flush, or even very slightly above the rim of the pulley.
                          Tension should be such that it can be depressed just under 1/2" in the middle of the run.
                          HTH
                          #459075
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, a guide for belt tensioning can be found on page 76 of Section 3 plenty more information here too.
                            Regards Nick.
