Chester conquest
Chester conquest
Home › Forums › Workshop Tools and Tooling › Chester conquest
  • #17996
    here again
      @hereagain
      tailstock lock
      #224956
      here again
        @hereagain
        Having got thoroughly fed up trying to get the spanner in to bolt up the tailstock it would be very simple to drill and tap a hole straight down onto the bed or v..What material should I use for the set screw so as not to damage the bed please?
        #224961
        frank brown
          @frankbrown22225
          No thats not the way to do it. Remove the nut. Find out its thread and tap a bit of 1" long 3/4" rod to this thread. Cross drill your new nut at a point higher then the bit of thread sticking through the tailstock. Screw your nut on and see where the hole lines up with respect to the casting. Now to lock the tailstock, the hole must be behind the front bit of the casting. So you can add washers to suit or if you are ambitious, turn a bit of the actual thread end. A washer is required anyway. If its not fitted fit, a strong spring between the clamp and the underneath of the tailstock.
          If you have succeeded, putting a bar through your cross hole and pulling it should lock the tailstock, pushing the bar away will unlock the tailstock. The spring it to push the clamp of the bed as it has a habit of freezing to the bed.
          Myfords for all their years in the trade never thought of this either !!
          Frank
          #224963
          here again
            @hereagain
            Oh yes!
            Thank you Frank
            Actually I saw a Chester mill/lathe with a bolt straight through base of tailstock..Assumed aluminium would nt do damage but still not very nice..
            Too late to sell the idea to Myford..Jonathon
            #224967
            Les Jones 1
              @lesjones1
              I think you would be better off doing the job properly by fitting a camlock. Here are two links that should give you enough information.
              Les.
              #224968
                It's not too hard to make a lever clamp for the tailstock of a mini-lathe by copying the design used on more recent versions.
                I used to have one based on a bicycle hub lock, but it was fussy to adjust, so I made a more direct copy – it needs a bit ore force, but works well and is more tolerant of misadjustment.
                Michael Cox 1
                  @michaelcox1
                  There is a good example of a DIY camlock on the gadgetbuilder website, see:
                  http://www.gadgetbuilder.com/CamLock.html
