Cast iron
Cast iron
Home › Forums › General Questions › Cast iron
  • #102573
    Ziggar
      @ziggar
      Hi all
      am looking to buy a chunk of cast iron that when i finish with it will have a size of 130 mm diam X 30mm thick
      have tried several suppliers that i have bookmarked and none seem to have it in the size i need or even carry cast iron at all
      so does anyone know of any suppliers that they know would have this and deliver nationwide – UK
      TIA
      #22298
      Ziggar
        @ziggar
        where to buy
        #102580
        Nicholas Farr
          @nicholasfarr14254
          Hi Ziggar, have you tried The College Engineering Supply **LINK**
          Regards Nick
          #102582
            M-machine do 130mm CI cut to length at £9.32/25mm so cost you about £12 but that may be a bit tight on your finished Dia so they also do 140mm at £10.20/25mm.
            Ian S C
              @iansc
              When buying cast materials, the actual size is usually a given amount oversize to allow for machining, so the 130 mm bar should machine to 130 mm. Ian S C
              #102586
                I do find that CI is quite tight to size you may be thinking of cast bronze which usually has a bit more to play with, just measured some CI I have.
                80mm = 80.91
                70mm = 70.83
                60mm = 60.12
                45mm = 45.47
                25mm = 25.44
                So very little to play with.
                #102614
                colin hawes
                  @colinhawes85982
                  I don't know the application for your cast iron project, but sometimes the obvious is easy to miss.When I design things I take standard stock sizes into account so as to involve minimum waste and machining.Dooes it really have to be exactly 130 mm finished? Colin
                  #102699
                  Ziggar
                    @ziggar
                    Hi all
                    appreciate the links
                    Thanks
