Cardibe inserts
Cardibe inserts
Home › Forums › Workshop Tools and Tooling › Cardibe inserts
  • #19362
    Dave Harding 1
      @daveharding1
      #413038
      Dave Harding 1
        @daveharding1
        I purchased some 16mm carbide inserts the hole in the centre is smaller than my current ones I can not get the retaining screw through the hole. I thought they would all be a standard size.
        #413041
        Dave Harding 1
          @daveharding1
          Oops they are VCMT
          #413043
          Mark Rand
            @markrand96270
            They are of a standard size, but there are many standards…
            #413061
            AdrianR
              @adrianr18614
              Hi Dave,
              I found this site helped me understand the arcane numbering. Now I look again it does look like the standards do not specify hole diameter which sounds right screwy.
              Maybe someone here with more experience can shed some light on this?
              Adrian
              #413068
              Bear G 1
                @bearg1
                Hi Dave,
                Are you absolutely sure they haven't sent you VNMG tips by mistake? They're the same shape but are designed to clamp with a pin on a cam operated by a grub screw; the hole is smaller on this tip type. The normal ones I use are VBMT which are often used for fine finishing.
                Bear
                #413078
                Ian S C
                  @iansc
                  You could forget the hole and use holder with a bridge clamp, as I have done on my home made tool. The tip is 16 mm with no chip breaker, it's the type I use on the 50 mm face mill.
                  Ian S C
                  #413088
                  Hollowpoint
                    @hollowpoint
                    I might be being a bit radical here but you could always send them back for a refund or exchange?
                    Edited By Hollowpoint on 07/06/2019 11:48:19
                    #413110
                    Thor 🇳🇴
                      @thor
                      Hi Dave,
                      Some of the inserts I have has a small hole in the centre, they are intended for holders with a short pin on the underside of the bridge clamp (see Ian's post), the pin prevents the insert from moving when taking heavy cuts (well, so I was told when I bought the inserts). May be yours can be used in a similar holder.
                      Thor
                      #413148
                      old mart
                        @oldmart
                        You might be lucky enlarging the hole with a diamond file out of one of those cheap sets of needle files.
                        As already mentioned, are you sure the inserts are the same as what you have already got? VCMT have only 2 edges at a 7 degree angle and VNMG have square ends and 4 edges.
                        #413400
                        Dave Harding 1
                          @daveharding1
                          I double checked and with the help of google determined that they are actually VNMG not VCMT as I thought.
                          My mistake I ordered the wrong inserts. As I have quite a few of them I decided to buy a suitable tool holder and use them.
                          Thanks for the feedback.
                          #413413
                          Ian S C
                            @iansc
                            The tool holders are easy enough to make, although the one in the photo was fairly heavy going as is is a bit of a car half shaft/rear axle, the bridge piece is just a bit of steel from the junk box, the erosion on it was from some heavy work on some 316 stainless(I was warned there would be miles of sharp swarfe). The bolt is 10 32 unf 5/8" .
                            Ian S C
                            #413444
                            old mart
                              @oldmart
                              I have bought lots of the cheap Chinese toolholders for carbide inserts on ebay, they are almost as good as the big named brands.
                               The second letter "c" indicates a positive tip angle of 7 degrees, and the insert is held level in the toolholder and the "n" means neutral with no relief (square end) with the insert dipping down 7 degrees in the toolholder to provide cutting relief. When you get the other holder the difference will be obvious.
                              Edited By old mart on 09/06/2019 19:11:11
