Band saw running off true
Home Forums General Questions Band saw running off true
  • #23831
    anchorman
      @anchorman
      #187584
      anchorman
        @anchorman
        I have an old 4 1/2" metal cutting bandsaw which has suddenly started running off true.
        I tried to cut a 1/2" square piece of mild steel and noticed that it had cut about 45degrees out of true, does anyone know why this has suddenly started to happen . The blade is tight and the guide rollers are as near to the cut as I can get them .
        #187587
        mechman48
          @mechman48
          Try re-squaring the blade with a Engineers square sat on the base in between the vice jaws up against the saw blade & readjust the blade guides…
          George
          #187588
          simondavies3
            @simondavies3
            My own experience when this happens – it is time to replace the blade which has probably become blunt.
            Simon
            #187590
            Jon Gibbs
              @jongibbs59756
              As Simon says this is usually down to the set having gone off one side of the blade so that the cut is biassed towards one side.
              …but if it really "suddenly" started to happen then it may be that the blade guides have slipped and so George's approach is the right one?
              HTH
              Jon
              Edited By Jon Gibbs on 24/04/2015 11:43:54
              #187595
              paul 1950
                @paul1950
                blunt or poor quality blade
