Another Mystery Tool
Home › Forums › General Questions › Another Mystery Tool
  • #226726
    Brian H
      @brianh50089
      I bought this recently via ebay and wondered is anyone recognizes the type.
      There is no makers name on it but it is clearly another version of a Clarkson Autolock though a bit more complicated.
      One of the threaded oval plates is missing but as it's for the largest size of cutter I'll be unlikely to need a replacement although It wouldn't take much effort to make one.
      #24399
      Brian H
        @brianh50089
        Holder for screwed end & slotdrills.
        #226731
        Chris Evans 6
          @chrisevans6
          That looks home made to me. I have seen most variations on the Clarkson theme.
          #226748
          ega
            @ega
            Brian Hutchings:
            An interesting design. The provision for restraining the cutter axially seems different from the Clarkson. Perhaps you would test for the effectiveness of this and report back?
            #226753
            MW
              @mw27036
              what an intriguing find, If it is home made then they were no stranger to delicate machining needed for the collets.
              Michael W
              #226761
              Bazyle
                @bazyle
                MMMM home made but in the style of the Acramil with the thick end of the collet at the bottom of the socket?
                #226770
                daveb
                  @daveb17630
                  It resembles the early Osborn Titanic milling chuck except the threaded oval plates were not used by Osborn, they had a disc with a slot. The center pin which locates in the end of the cutter is missing, easy enough to make one. The chuck works thus, rotation of the cutter causes the oval plate (which is restrained from rotating) to move down the cutter thread, pushing the sleeve downwards to compress the collet. They do grip the cutters very well. Perhaps it is Mr Osborn's original prototype.
                  #226775
                    I've got an Osborn Titanic II, I don't know if the Mk.1 was different, but that's nothing like my chuck.
                    Is there a locating cone missing from the inside of the body?
                    Brian H
                      @brianh50089
                      Many thanks for the replies, I did wonder if there should be a centre cone. I'll try and get a better picture of the internal details of the body.
                      Parts of it look home made, for instance the threads are rougher than would be expected on a professionally made item and it seems to have spent some time half submerged in water. The outer body looks to have been chrome plated but was damaged by vice jaws so I have machined it smooth.
                      I think it will do any milling that I might be doing.
                      #226866
                      daveb
                        @daveb17630
                        Neil, yes, the Titanic II is different, 1 piece collet. I use one of these, also a more recent Soba chuck, this is a direct copy, the collets are interchangable.
                        Brian H
                          @brianh50089
                          p1130309.jpgTook a couple more pictures.
                          #226959
                          Brian H
                            @brianh50089
                            The picture inside the body shows a 3/8" hole that goes down about 1 1/4" and I've found a piece of 3/8" silver steel that has been turned down to use as a temporary centre. If I clean it up it will serve as a support cone.
                            #226987
                            Bazyle
                              @bazyle
                              Is the hole straight of tapered? Clarksons use a 0 Morse taper centre. The use of an oval thread plate seems a bit awkward to make suggesting it was a patent busting measure perhaps.
                              #227140
                              Brian H
                                @brianh50089
                                Bazyle, the hole is a straight 3/8" inches.
