Another myford motor question
Home › Forums › Manual machine tools › Another myford motor question
  • #505003
    Mark Cunliffe 3
      @markcunliffe3
      Hi all,
      I have a 50 year old ML7 which appears to have the original single phase 1/3hp Crompton Parkinson motor.
      The motor runs in both directions however it had a bit of a knock. Closer inspection shows an amount of end float in the shaft and play In the bearings.
      I have read all the recommendations on upgrading etc but don't currently have the funds.
      My question is, has anybody replaced the bearings in one of these motors, was it successful, are they standard sizes or oddball.
      Thanks for any help
      #14070
      Mark Cunliffe 3
        @markcunliffe3
        #505035
        David George 1
          @davidgeorge1
          They have standard bearings and there should be wavy spring washers to take up any end float which are also available. Strip down is simple take photos at all stages ie wiring connections and where washers go etc. Check and clean the centrifugal switch.
          David
          #505040
          Steviegtr
            @steviegtr
            Posted by David George 1 on 02/11/2020 22:36:18:
            David
            +1 Look up a bearing supplier near you. You may be surprised at how cheap they are & from a supplier you should be able to get good quality like Fag etc.
            Steve.
